Ricoh Aficio SP C240SF Colour Laser Multifunction Printer
Quicklinx: 7WGWWS00 Mfr#: 974220
Compact A4 desktop colour laser MFP with high specification duplex copy, scan, and print features with fax and PC fax - with excellent image quality and industry standard connectivity.
Ahead of the competition - What sets it apart
One of the smallest desktop colour laser MFP in the world - very small footprint taking up little desktop space One of the lowest mainframe price in its MFP class Competitive AiO cartridge prices Faster first print time at 14s than nearly all competitors Supports one of the heaviest weights of paper from the standard tray (160 gsm) - compared to other MFPs in its class The simplest maintenance with only 5 easy steps to replace consumable items Standard auto duplex printing in such a compact MFP beats all competition Fast matched 16 ppm colour and mono speed compared to either single digit colour speeds or unmatched copy and print speeds from MFP competitors in its segment. Best security features in its class with Locked Print and Operation Panel.
Features that save office space
Very small footprint takes up little desktop space - front access to paper and supply changing means little side space needed - optional paper tray fits below the main unit without increasing footprint.
Features that save printing, copying and document creation time
Fast 16 ppm print speed in colour and B/W and powerful 400 MHz processor/256 MB standard RAM means no waiting around for prints - printing in colour does not slow users down.
Outstanding reliability - maximum up time with a durable construction capable of 30k prints/month is backed by Ricoh with a one-year on-site warranty (depending on purchase plan). Fast 10s "power on" feature from low power recovery mode saves waiting time "Scan Once Copy Many" feature means originals can be used while they are being copied - saving time Electronic collation prints multiple copies of multi-page documents in the correct numerical sequence using RAM memory - saving manual collation PC Faxing - faxes can be sent from the workstation without walking up to the Operator Panel, saving time Productive Driver Features Booklet printing feature automatically arranges and paginates your document so you can easily fold and staple it into a booklet
Features that save device management time
Easy driver installation gets you printing with only a few clicks Administrators can manage the printer remotely using Embedded Web Admin Tools - no need to visit the printer to change settings or load additional software E-Mail Alert Function - When networked, the printer can be configured to send an e-mail alert when it is running out of toner or when it has a status problem. IT administrators can remotely manage the printer proactively and not in a costly reactive manner.
Features that give high quality prints, copies and faxes
High quality 2,400dpi colour printing for excellent colour quality AiO Colour cartridges - the entire image process is refreshed for the colour at hand every time an AiO cartridge is replaced Black overprint feature - enhances text quality by printing black last Productive Driver Features Letterhead Mode prints on the backside of a letterhead sheet first, in order to prevent interference with the facing letterhead page PC Faxing preserves digital image quality.
Features that save printing, and copying costs
Toner "save" feature means you can print more pages from the same cartridge N-Up printing allows you to print up to 16 page images on one sheet of paper Standard duplex print and copying feature saves paper usage and reduces postage costs Combine Copying allows you to combine up to 4 x 4 A4 sheets onto one side - saving output costs PC Faxing saves costs by eliminating unnecessary cover and fax page printing.
Features that enhance office workflow and ease of use
Supports all paper types and sizes A6 -A4 including envelopes and weights up to 160 gsm from the standard tray - no need to use the bypass Full front operation makes printer easy to use and maintain Adjustable scanner mechanism slides towards rear of main unit for easy access to top exit tray. Replacement of colour units is simple and can be done with one hand by any office staff Minimum user intervention with only 5 consumable items to change - compared to older types of competitive MFPs with up to 9 units Modern Design - curved modern design looks nice in an office and cable cover protects ports and neatly organises cables for a pleasant working environment Operation Panel and LED indicates when supplies need to be changed Advanced scanning to folder/FTP/e mail speeds the sharing of information to multiple recipients instantly and simultaneously Programmable Scan Settings can register basic settings such as document size, scanning resolution, and image density settings with specific Scan-to destinations - improving scan to workflows. Bundled Document Management Software assists users in managing digital files, enabling viewing, editing, sending, backing up and OCR conversion.
  • The perfect fit
    Small in size, this printer neatly fits into your workspace. The front design features a USB host for effortless scanning to USB. The ID card copy facility enables both sides of a document to be copied onto a single sheet, saving paper and time. Plus the four-line operational panel is raised so you can see the LED even when seated. Everything, including paper and toner replacements, is operated from the front panel for ease of use.
  • Increased productivity
    Waiting for your printer to warm up wastes valuable time. This printer is operational in 30 seconds. The first print arrives in just 14 seconds. Then you can rely on 16 ppm with the SP C240SF. This means you benefit from faster turnaround times and increased productivity to make the most of your business.
  • Save on paper and costs
    Enjoy the low TCO. Save paper and reduce costs by copying and printing duplex. Standard on this printer, this function allows you to produce fast double-sided copies. Plus the high yield all-in-one toner saves on cost and time. Because you can print high impact, professional-looking documents on a variety of media in-house, you save outsourcing costs as well.
  • Versatile 4-in-1
    With this multifunctional A4 color printer you can copy, print, scan and fax in one. Color scans look attractive, professional and are easier to read. Scanning to email, a folder and FTP saves time and speeds up communications. Faxing to and from your PC is productive and also saves time.
  • Energy efficiency
    Today, more and more SMBs (Small and Medium-sized Businesses) are being encouraged to stop energy waste and reduce their CO2 emissions. The high uptime and reliable SP C240SF printer is designed to help. It saves energy with its low power consumption and short warm-ups as well as expense.
Ricoh SP C240SF - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (colour)
Max Copying Speed
Up to 16 ppm (mono) / up to 16 ppm (colour)
Max Copying Resolution
Up to 600 dpi (mono) / up to 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 2400 x 600 dpi (mono) / up to 2400 x 600 dpi (colour)
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Fax Resolutions
200 x 200 dpi, 200 x 100 dpi
Scanning
1200 x 1200 dpi
Original Size
A6 (105 x 148 mm) (min) - 216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
35 sheets
Media Size
A6 (105 x 148 mm) (min) - A4 (210 x 297 mm) (max)
Standard Media Capacity
250 sheets
Max Media Capacity
750 sheets
Bypass Feeder Capacity
1 sheet
Output Trays Capacity
150 sheets
Connection Availability
USB 2.0, LAN
Office Machine Features
Scan to e-mail, scan to folder
AC 230 V (50/60Hz)
42 cm x 49.3 cm x 47.6 cm
30 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - colour
Display
2 lines x 16 characters
USB 2.0, LAN
Standard Memory
256 MB 256 MB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Printing
Max Printing Speed
Printer Drivers / Emulations
Windows GDI driver
Scanning
Optical Resolution
1200 x 1200 dpi
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Fax Resolutions
Max Battery Backup Time
1 hour(s)
Document & Media Handling
Min Original Size
A6 (105 x 148 mm)
Max Original Size
216 x 356 mm
Original Type
Sheets
35 sheets
Min Media Size
A6 (105 x 148 mm)
Max Media Size
A4
Min Media Weight
60 g/m²
Max Media Weight
160 g/m²
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm)
250 sheets
Max Media Capacity
750 sheets
1 sheet
150 sheets
Input tray - 250 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m² , Output tray - 150 sheets , Bypass tray - 1 sheet size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 160 g/m² , ADF - 35 sheets
Speed Details
Copying: up to 16 ppm - B/W , Copying: up to 16 ppm - colour , Printing: up to 16 ppm - B/W , Printing: up to 16 ppm - colour
1 x USB 2.0 , 1 x LAN
Network Protocols
TCP/IP, IPP, IPv4, IPv6, Bonjour
Operating System Support
MS Windows XP, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows 7, Apple Mac OS X 10.3 - 10.6, MS Windows Vista, MS Windows Server 2008, MS Windows Server 2008 R2
Software Included
Presto! PageManager, Web Image Monitor
AC 230 V (50/60Hz)
1.3 kW
Power Consumption Sleep
10 Watt
Direct Printing Specifications
PictBridge
Warm-Up Time
30 sec
First Copy Out Time B/W
14 sec
First Copy Out Time Colour
14 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages
ENERGY STAR Certified
42 cm
49.3 cm
47.6 cm
30 kg
