As your long-term data storage grows, so does your need for a dependable and efficient way to keep it protected. Based on the world's fastest-growing tape technology, Quantum's LTO tape drives work seamlessly with scalar tape libraries and automatically match the tape drive speed to that of the host, optimizing performance and increasing reliability. Plus, Quantum's LTO tape drives are easy to deploy and upgrade - perfect for small, midsized, and corporate storage environments.
LTO-5 is the ideal solution for archive and long-term data retention due to its industry leading capacity, fast throughput rates, and security features.
- Quantum LTO-5 HH SAS HBA Bundle - tape drive - LTO Ultrium - SAS-2
- Tape drive
- Recording Standard
- LTO Ultrium 5
- Enclosure Type
- External
- Interface Type
- SAS-2
- Key Features
- Encryption
- 22.4 cm x 30.1 cm x 7.9 cm
- 3.7 kg
- Black
- Storage Removable
- LTO Ultrium
- Storage Removable Capacity
- 1.5 TB (native) / 3 TB (compressed)
- Supported Tape Cartridges (Read and Write)
- Ultrium 4, Ultrium 5
- Data Transfer Rate (native)
- 140 MBps (504 GBph)
- Data Transfer Rate (compressed)
- 280 MBps (1008 GBph)
- Power
- AC 120/230 V (50/60 Hz)
- OS Required
- SunSoft Solaris, Red Hat Linux, SuSe Linux, Microsoft Windows
- Microsoft Certification
- Works with Windows Vista
- 3-year warranty
- Tape drive - LTO Ultrium
- LTO Ultrium 5
- Enclosure Type
- External
- Interface Type
- SAS-2
- Key Features
- Encryption
- Built-in Devices
- Led panel
- Enclosure Colour
- Black
- 22.4 cm
- 30.1 cm
- 7.9 cm
- 3.7 kg
Storage Removable
- LTO Ultrium
- Capacity
- Average Seek / Access Time
- 56 sec
- Buffer Size
- 256 MB
- 1 x SAS-2 - 26 pin 4x Shielded Mini MultiLane SAS (SFF-8088)
- Media Included Qty
- 1
- Included Accessories
- Cleaning cartridge
- Cables Included
- 1 x SAS cable - 2 m
- MTBF
- 250,000 hour(s)
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- CSA, VCCI, BSMI, CISPR 24, EN55022, ICES-003, EN55024, CISPR 22, CB, EMC, MIC, AS/NZS 3548, SII, UL 60950-1, IEC 60950-1, EN 60950-1, AES-256, FCC CFR47 Part 15 B, BSMI CNS 14336
- Power supply
- Voltage Required
- 21.4 Watt
- OS Required
- Limited warranty - parts - 3 years - shipment - response time: 2 business days
- 10 °C
- 40 °C
- 20 - 80%
