When expanding data storage capacity, deploying multiple servers can lead to complexity in management and dramatically increased costs. QNAP TX-500P expansion enclosure provides a flexible expansion alternative designed with easy setup in mind for scaling up your NAS storage space. The TX-500P provides an additional 5 hard drives providing expanded capacity for the NAS, making it ideal for data backup, 4K digital media collection and video surveillance storage with blazing-fast data transmission performance.
Easily add additional drive capacity to your NAS
Simply connect the TX-500P to the NAS and power it on. The NAS will automatically detect the hard drives in the TX-500P as newly installed local drives. The Thunderbolt NAS capacity can then be seamlessly expanded as a large volume. -
Missing mode protection
If your TX-500P is accidentally disconnected, your NAS enters the missing mode and blocks I/O access to protect the stored data. The system can then recover from the missing mode to the normal state with data staying intact. -
Efficient backup solution
In addition to expanding an existing volume, you can use the TX-500P as a flexible external storage to perform speedy and secure backup tasks for your NAS. The QNAP RTRR or rsync service lets IT administrators back up NAS data to the TX-500P on a real-time or scheduled basis. -
Smart power design
The TX-500P automatically powers on and off with your NAS, allowing for total convenience and energy saving. -
Flexible drive selection
The TX-500P offers high flexibility in hard drive selection. IT administrators can choose high-capacity SATA HDDs for large data archiving, or high-speed and high-stability SSDs for I/O intensive operations. -
Excellent hardware design
The TX-500P includes a full internal PSU to provide ample power even under sustained full load. The well-ventilated chassis and smart fan help to provide efficient cooling for better stability and reliability, with the fan enabling efficient heat removal even when all 5 drives are under full operation simultaneously.
- QNAP TX-500P - hard drive array
- Hard drive array
- Interface
- Thunderbolt 2
- Installed Devices / Modules Qty
- 5 (installed) / 5 (max)
- Supported Drives
- SATA-600
- Built-in Devices
- Status LCD
- Storage Controller
- SATA (SATA 6Gb/s)
- Hard Drive
- 5 x 8 TB HDD
- Power
- AC 120/230 V - 50/60 Hz
- 21.06 cm x 23.54 cm x 18.52 cm
- 5.1 kg
- Hard drive array
Chassis
- Built-in Devices
- Status LCD
- 5
- Supported Devices / Modules Qty
- 5
- Supported Drives
- SATA-600
Storage
- HDD Array External Interface
- Thunderbolt 2
Storage Controller
- SATA
- Interface Type
- SATA 6Gb/s
- Data Transfer Rate
- 600 MBps
Hard Drive
- HDD
- Capacity
- 5 x 8 TB
- Expansion Bays
- 5 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
- 2 x Thunderbolt 2
- Security lock slot (cable lock sold separately), built-in cooling fan
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- 21.06 cm
- 23.54 cm
- 18.52 cm
- 5.1 kg
- 5 °C
- 35 °C
- 5 - 95% (non-condensing)
