The TS-853U-RP is a powerful, reliable, secure and scalable NAS solution designed for mission-intensive business applications and to meet fast growing data storage needs. The TS-853U-RP supports SATA 6 Gb/s drives and delivers high performance with persistent throughput, providing a comprehensive storage solution for SMBs to build a reliable private cloud.
Energy-saving yet powerful processor
Equipped with a powerful processor with energy-efficient DDR3L RAM, coupled with the support of SATA 6 Gb/s, 4 Gigabit LAN ports and HDMI output, the TS-853U-RP is a powerful NAS that delivers up to 430 MB/s throughput. The TS-853U-RP can also automatically increase the processor's clock rate when needed for CPU-intensive tasks. The TS-853U-RP's fast encryption and decryption performance provides transfer speeds of up to 273 MB/s with AES 256-bit volume encryption, boosting system performance & security while ensuring the safety of sensitive business data stored in the TS-853U-RP. -
Economical storage expansion with scale-up solution
The TS-853U-RP offers a high performance yet affordable storage solution to fulfill the needs of businesses in archiving rapidly growing data & large files. The TS-853U-RP supports capacity expansion by connecting a QNAP expansion enclosure. With the QNAP scale-up solution, the raw storage capacity can be expanded on demand, making the TS-853U-RP an ideal file center with a large storage capacity for business data. -
QTS - simple and efficient
Thanks to the intuitive user interface of QTS, system operations of the TS-853U-RP are smooth and handy. Its intelligent desktop allows you to find desired functions quickly, create desktop shortcuts or group shortcuts, monitor important system information on a real-time basis, and open multiple application windows to run multiple tasks concurrently, bringing greater operating efficiency. -
High reliability design ensuring business continuity
The business-ready TS-853U-RP is designed to provide continuous operation and services. The support for comprehensive RAID configurations and hot-swapping allow for replacing hard drives without service interruption. QNAP's advanced RAID recovery technology also helps if any healthy drives are removed from a degraded RAID volume by mistake. The system can be recovered by reinserting the wrongly removed hard drives so the data can still be accessible. The TS-853U-RP delivers high reliability and efficiency with 4 LAN support for multiple port-trunking modes including fail-over support. -
File synchronization across multiple devices
The Qsync utility turns your TS-853U-RP into a safe data center for file synchronization with a large storage capacity. Any file uploaded to the TS-853U-RP will be made available for all linked devices, such as computers, laptops or mobile devices. Qsync is especially useful for frequent travelers to manage files and always have updated files on different devices. Qsync provides multiple ways of file synchronization and group file sharing, greatly enhancing the flexibility of collaboration. -
Disaster recovery solutions brings peace of mind
The TS-853U-RP offers various data recovery options. RTRR (Real-Time Remote Replication) supports real time or scheduled data backup to a remote Turbo NAS or FTP server and synchronizes files to a remote folder from a local folder with better backup efficiency and reduced backup time. -
Monitor and manage multiple NAS with Q'center
Q'center turns your TS-853U-RP into a central management system to manage multiple Turbo NAS units. After installing Q'center in the QTS App Center, you can use the TS-853U-RP to centrally manage multi-site Turbo NAS for monitoring system logs, managing firmware updates and maintenance; and enjoy major benefits including ease-of-use, cost-efficiency, convenience and flexibility. Managing multiple Turbo NAS becomes so easy and efficient with Q'center. -
Comprehensive security options
In open network environments, business data may be exposed in a potential hack. The TS-853U-RP provides numerous security options, such as encrypted access, IP blocking, and more. IT administrators can also control the access rights of each user to different folders, preventing unauthorized access to important files. The TS-853U-RP is validated with military-level FIPS 140-2 AES 256-bit encryption, preventing sensitive business data from unauthorized access and breach even if the hard drives or the entire system were stolen.
- QNAP TS-853U - NAS server - 40 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 40 TB
- Installed Devices / Modules Qty
- 8 (installed) / 8 (max)
- 48.2 cm x 53.4 cm x 8.9 cm
- Processor
- 1 x Intel Celeron 2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, 5 hot spare, 6 hot spare, 10 hot spare
- Hard Drive
- 8 x 5 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.1
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- 40 TB
- 48.2 cm
- 53.4 cm
- 8.9 cm
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 8 GB (supported) - DDR3L
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
- HDD - hot-swap
- Capacity
- 8 x 5 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, PPTP, UDP/IP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- VPN support, trunking, LDAP support, VLAN support, wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, antivirus analysis, IP address filtering, firmware upgradable, proxy server, MySQL server, web server, backup server, download client, file sharing, event log, Trivial File Transfer Protocol (TFTP) support, RADIUS support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, Network Access Protection (NAP), bandwidth control, IPv4 support, surveillance station, teaming support, PXE support, DLNA Media Server, Apple Time Machine compatible, Link Aggregation Control Protocol (LACP), TFTP server, DHCP client, e-mail notification, cloud backup, VPN Server
- Encryption Algorithm
- SSL, 256-bit AES
- IEEE 802.3ad (LACP), IEEE 802.1x, UPnP
- Expansion Bays
- 8 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin
- 4 x Ethernet 1000Base-T - RJ-45 , 4 x USB 3.0 - Type A , 1 x HDMI output , 1 x management
- Cables Included
- 2 x network cable
- Audible alarm, wake on LAN, built-in 2 cooling fans
- Power Device
- Internal power supply
- Installed Qty
- 1
- Max Supported Qty
- 1
- Voltage Required
- Power Provided
- 250 Watt
- QNAP QTS 4.1
- 0 °C
- 40 °C
- 0 - 95%
