QNAP Virtualization Station enables virtualized desktop operations on the Turbo NAS for managing multiple virtual machines. With the easy-to-use interface, you can centrally manage all virtual machines created on the Turbo NAS with least efforts.
Operate VMs as remote desktops
Enjoy utmost convenience by operating Windows, Linux and UNIX-based VMs as remote desktops. A list of buttons is provided on the left side of each individual VM display, allowing users to suspend, shutdown, force shutdown, reset, bring up key combinations & function keys, and even take snapshots for the VMs. -
Fast virtual machine creation
Virtualization Station provides several default templates for quickly choosing a proper one to create a virtual machine. Advanced users can create custom templates, or manually create a virtual machine without choosing from the templates. -
Virtual machine import/export
Virtual machines of various formats can be easily import to and export from the Virtualization Station with simple steps. The administrators will enjoy extreme flexibility in arranging IT resources across machines. -
Snapshot
Virtualization Station provides snapshot feature to record the virtual machine system status at a point of time. At the event of virtual machine failure, users can quickly roll it back to the snapshot time to ensure continual system operation. -
User-based permissions settings
The Virtualization Station administrator can create users and set proper permissions for each Virtual Machine (VM), helping to efficiently manage and allocate VM resources for users with different needs. With these permissions, users can work independently on their VM without worrying about their work being interrupted or data being lost because another user has accidentally powered-off the VM.
- QNAP TS-853 Pro Turbo NAS - NAS server
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Installed Devices / Modules Qty
- 0 (installed) / 8 (max)
- 29.82 cm x 23.54 cm x 18.52 cm
- 7.3 kg ()
- Processor
- 1 x Intel Celeron 2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 24
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- UNIX, Linux, Microsoft Windows XP or later, Apple MacOS X or later, Microsoft Windows Server 2003 or later
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 0 GB
- 29.82 cm
- 23.54 cm
- 18.52 cm
- 7.3 kg ()
- Built-in Devices
- Led panel
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 2 GB (installed) / 8 GB (supported) - DDR3L
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
- Data Link Protocol
- TCP/IP, PPTP, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB
- Remote Management Protocol
- SNMP, Telnet, HTTP, HTTPS, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Wake on LAN (WOL), Syslog support, E-mail alert, print server, IPv6 support, proxy server, web server, backup server, download client, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, BitTorrent Client, UPnP Media Server, IPv4 support, surveillance station, DLNA Media Server, DHCP client, e-mail notification, cloud backup, VPN Server, Apple AirPlay
- Encryption Algorithm
- FIPS 140-2, 256-bit AES
- DLNA CERTIFIED, UPnP
Security DVR
- 24
- Expansion Bays
- 8 (total) / 8 (free) x hot-swap - 2.5" / 3.5"
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0 - Type A , 3 x USB 3.0 - Type A , 1 x HDMI output - Type A
- Cables Included
- 2 x network cable
- Security lock slot (cable lock sold separately), built-in cooling fan
- Security Slot Type
- Kensington security slot
- Power Device
- Internal power supply
- Voltage Required
- 59.54 Watt
- Power Provided
- 350 Watt
- OS Required
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
