The TS-1263U-RP is a powerful network storage system powered by a high-performance AMD quad-core processor. It uniquely provides 10GbE at a budget price to maximize ROI, and doubles the encrypted file transfer performance with the AES-NI hardware-accelerated encryption engine to over 800 MB/s. Powered by the QTS operating system, the TS-1263U-RP provides versatile all-in-one server functionalities as well as unique features including Virtualization Station, which allows users to run VMs on the same device. The TS-1263U-RP is designed for small and medium-sized businesses looking for backup, restoration, private cloud, storage for virtualization, and to future-proof their IT infrastructure for 10GbE networks.
- QNAP TS-1263U Turbo NAS - NAS server - 24 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet / 10Gbps SFP+
- Enclosure Type
- Rack-mountable - 2U
- Total Storage Capacity
- 24 TB
- Installed Devices / Modules Qty
- 12 (installed) / 12 (max)
- 48.2 cm x 53.4 cm x 8.9 cm
- Processor
- 1 x AMD G-Series 2 GHz (Quad-Core)
- Storage Controller
- RAID SATA 6Gb/s RAID RAID 0, 1, 5, 6, 10
- Hard Drive
- 12 x 2 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- RAM
- 4 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- QNAP QTS 4.2
- System Requirements
- UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8 (32/64 bits), Microsoft Windows Server 2012 R2
- NAS server
- Host Connectivity
- Enclosure Type
- 24 TB
- 48.2 cm
- 53.4 cm
- 8.9 cm
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- Max Supported Qty
- 1
- RAM
- 4 GB (installed) / 16 GB (supported) - DDR3L
- Flash Memory Installed
- 512 MB
Storage Controller
- RAID
- Interface Type
- SATA 6Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 12 x 2 TB
- Interface Type
- SATA 6Gb/s
- Data Link Protocol
- TCP/IP, PPTP, L2TP, IPSec, iSCSI, SMTP, FTP, DHCP, Bonjour, SMB, DDNS
- Remote Management Protocol
- SNMP 2, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Apple Bonjour Protocol, File Level Security (ACLs), DHCP, DDNS, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
- Trunking, LDAP support, wake on LAN (WOL), Syslog support, manageable, E-mail alert, print server, IPv6 support, proxy server, backup server, file sharing, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, SSH support, iTunes server, Jumbo Frames support, DHCP server, FTP server, SMS alert, bandwidth control, IPv4 support, surveillance station, teaming support, DLNA Media Server, Apple Time Machine compatible, DHCP client, e-mail notification, cloud backup, VPN Server, SFTP client, SNMP support, Apple AirPlay, Dropbox support
- Encryption Algorithm
- SSL, TLS, 256-bit AES
- UPnP
- Expansion Bays
- 12 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- Expansion Slots
- 2 (total) / 1 (free) x SO-DIMM 204-pin , 1 (total) / 0 (free) x PCI Express 2.0
- 4 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 1 x Ethernet 10Gb - SFP+
- Cables Included
- 2 x network cable
- Audible alarm, built-in 2 cooling fans, scheduled power on/off
- Power Device
- Internal power supply
- Voltage Required
- Power Provided
- 250 Watt
- QNAP QTS 4.2
- OS Required
- 0 °C
- 40 °C
- 5 - 95%
