QNAP TS-1079 PRO 10TB Desktop NAS
Quicklinx: 7P60WS00 Mfr#: TS-1079 PRO/10TB
  • Core i3
As the data value and volume of business data continue to rise, corporations need high-performance storage solutions which are secure, reliable, and easy to manage. The QNAP TS-1079 Pro, which serves as both IP-SAN (iSCSI) and NAS, can be easily utilized in different business and enterprise applications such as backup center, disaster recovery, file sharing, virtualization, and video editing storage.
The QNAP TS-1079 Pro offers a variety of security options such as encrypted access, IP filtering, policy-based automatic IP blocking, and more. In addition, full control of the NAS is offered down to the user and folder access rights to determine who can access the NAS and what can or cannot be accessed. The TS-1079 Pro is packed with security features to stop all unauthorized data access such as AES-256 volume-based encryption. The AES-256 volume-based encryption prevents sensitive data from unauthorized access and data-breach even if the hard drives or the device is stolen.
  • Secure
  • Reliable
    The TS-1079 Pro is reliable with built-in safety precautions to safeguard all data from any unforeseen problems. With multiple built-in features to guarantee no interruptions to the work flow of a business, the TS-1079 Pro is an efficient asset. The advanced RAID configurations and hot-swap capabilities are included to give RAID performance, protection and reduced rebuilding time. Moreover, the dual OS embedded on the DOM architecture ensures the system will boot up. If one of the two operating systems fails, the healthy operating system will boot up and operate normally while repairing the failed operating system.
  • Simple
    Setting up local or remote access with the TS-1079 Pro is painless and does not require any IT skills. All setup processes have been simplified so that most of the process is either automatic or can be completed by an installation wizard. The user-friendly web GUI allows administrators to easily manage the NAS so there is no need for an extensive knowledge of complex commands. Simple management tools such as instant SMS/email alert, the hard drive S.M.A.R.T. (Self-Monitoring, Analysis and Reporting Technology) feature, and system resource monitor are provided to keep administrators up-to-date on their NAS at all times.
  • NAS and iSCSI/IP-SAN solution for server virtualization
    With increasing virtualization of IT resources, the need for high performance storage is more essential than ever. The TS-1079 Pro offers excellent system architecture matched with 10 GbE networking performance designed to meet the needs of demanding server virtualization, such as VMware, Citrix, and Windows Hyper-V. 10 GbE network speeds greatly increase the agility of data transmission in a virtualized environment intensifying NFS and iSCSI connection performance.
  • High network bandwidth
    The TS-1079 Pro offers network expansion options which include dual-port 1 GbE and dual-port 10 GbE network expansion cards, to aggregate and boost network performance. The TS-1079 Pro includes two Gigabit (GbE) LAN ports which can be expanded to four GbE LAN ports or two 10 GbE LAN ports plus two GbE ports.
QNAP TS-1079 Pro Turbo NAS - NAS server - 10 TB
NAS server
Host Connectivity
Gigabit Ethernet
Total Storage Capacity
10 TB
Max Supported Capacity
30 TB
10 (installed) / 10 (max)
32.7 cm x 32.1 cm x 21.8 cm
9.8 kg ()
1 x Intel Core i3 2120 (Dual-Core)
Storage Controller
RAID SATA 6Gb/s RAID 0, 1, 5, 6, 10, JBOD, 5 hot spare, 6 hot spare, 10 hot spare
Hard Drive
10 x 1 TB
Network adapter GigE
RAM
2 GB
UNIX, Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Vista / XP / 7, Microsoft Windows Server 2008
NAS server
Host Connectivity
Gigabit Ethernet
10 TB
30 TB
32.7 cm
32.1 cm
21.8 cm
9.8 kg ()
Built-in Devices
Status LCD
Processor / Memory
Processors Installed
Number of Cores
Dual-Core
RAM
2 GB DDR3
Flash Memory Installed
512 MB
Storage Controller
RAID
Interface Type
SATA 6Gb/s
Max Storage Devices Qty
10
RAID Level
RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD, RAID 5 hot spare, RAID 6 hot spare, RAID 10 hot spare
Hard Drive
HDD - hot-swap - 2.5" / 3.5" shared
10 x 1 TB
Network adapter
GigE
Network / Transport Protocol
TCP/IP, FTP, DHCP, SMB
Remote Management Protocol
SNMP 2, SNMP, Telnet, SNMP 3, HTTP, HTTPS, TFTP, SSH
Network Services Compatibility
Apple Bonjour Protocol, DHCP, Microsoft CIFS, Network File System (NFS), FTP, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS, Web-based Distributed Authoring and Versioning (WebDAV)
Load balancing, LDAP support, VLAN support, Syslog support, manageable, E-mail alert, print server, IPv6 support, MySQL server, web server, backup server, file sharing, RADIUS support, Jumbo Frames support, DHCP server, FTP server, SMS alert, surveillance station, Apple Time Machine compatible, DHCP client
Expansion Bays
10 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
Expansion Slots
1 (total) / 1 (free) x expansion slot
2 x eSATA 3Gb/s , 4 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 3.0 - Type A
2 x network cable
Internal power supply
121 Watt
Power Provided
350 Watt
0 - 90%
