QNAP REXP-1220U-RP/24TB-RED PRO 12 Bay Rackmount NAS
Quicklinx: C2W6WS00 Mfr#: REXP-1220U-RP/24TB-RED PRO
The REXP-1220U-RP expansion enclosure is designed for expanding the storage space on a QNAP NAS by connecting multiple expansion enclosures via high-speed mini SAS cables. Featuring a 12 Gbps SAS interface on the chassis, the REXP-1220U-RP ensures fast data passthrough from 12 Gbps SAS-enabled QNAP NAS even when using 6Gbps hard drives. This is especially useful for large data applications that require high performance interconnection, such as video surveillance, archiving large data, and TV broadcast storage.
  • Plug and use, seamless capacity expansion
    Simply connect a REXP-1220U-RP to a QNAP NAS and power it on. The QNAP NAS will detect the hard drives in the REXP-1220U-RP as newly-installed local drives. You can seamlessly expand and manage the NAS capacity by using the powerful QTS Storage Manager.
  • Missing mode protection
    When the disconnection of a RAID expansion enclosure is detected, the NAS blocks IO access to protect data. The system can recover from missing mode to its normal state with the data staying intact.
  • High density, high efficiency and highly scalable
    The REXP-1220U-RP supports 12 hard drives and 96TB raw capacity in 2U rack space. The REXP-1220U-RP has two SAS wide ports (IN port and OUT port) for host connectivity and daisy-chaining respectively. Each SAS wide port combines four SAS channels (maximum 8 SAS channels supported per expansion enclosure), with each supporting 12Gbps full duplex speed. The solution delivers unprecedented performance of up to 48Gbps per host connection.
  • Powerful QTS Storage Manager
    The QTS Storage Manager neatly presents tools and options for managing system storage with an intuitive graphical user interface, which simplifies the process of NAS capacity expansion and REXP-1220U-RP management. IT administrators can easily monitor the health of the REXP-1220U-RP and the disks within it. When cascading multiple expansion enclosures in a rack, the Locate Disk and Locate Enclosure functions assist IT administrators in quick maintenance.
  • An excellent backup solution for the QNAP NAS
    In addition to expanding an existing volume, IT administrators can use the REXP-1220U-RP as a budget-friendly external storage to perform speedy and secure backup tasks for a QNAP NAS. The QNAP RTRR (Real-Time Remote Replication) or rsync service lets IT administrators back up NAS data to the REXP-1220U-RP on a real time or scheduled basis.
  • Flexible drive type and capacity
    The REXP-1220U-RP offers high flexibility in hard drive selection. IT administrators can choose enterprise-level SAS HDDs with high performance and high reliability for mission-critical applications, low-cost but high-capacity SATA HDDs for large data archiving, or high-speed and high-stability SSDs for I/O-intensive operations.
QNAP REXP-1220U-RP - storage enclosure
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Total Array Capacity
24 TB
SAS 12Gb/s
12 (installed) / 12 (max)
Supported Drives
SATA-600 / SAS-3
Built-in Devices
Led panel
Storage Controller
(SATA 6Gb/s / SAS 12Gb/s)
Hard Drive
12 x 2 TB HDD - hot-swap
AC 120/230 V - 50/60 Hz
Power Redundancy
43.9 cm x 52 cm x 8.8 cm
Storage enclosure
Enclosure Type
Rack-mountable - 2U
Chassis
Built-in Devices
Led panel
12
Supported Devices / Modules Qty
12
Supported Drives
SATA-600 / SAS-3
Storage
24 TB
HDD Array External Interface
SAS 12Gb/s
CPU
No CPU
Storage Controller
Interface Type
Data Transfer Rate
1.2 GBps
Max Storage Devices Qty
12
Hard Drive
HDD - hot-swap
12 x 2 TB
Expansion Bays
12 (total) / 0 (free) x hot-swap - 2.5" / 3.5" shared
3 x SAS 12Gb/s - 36 pin 4x Mini SAS HD (SFF-8644)
Lockable, built-in 3 cooling fans, hot-swappable fans
1 x SAS cable - 50 cm
EIA-310-D
2 x internal power supply - hot-plug
Max Supported Qty
2
Power Redundancy
Power Redundancy Scheme
1+1
162.47 Watt
Power Provided
400 Watt
43.9 cm
52 cm
8.8 cm
5 - 95% (non-condensing)
Sound Emission
46.1 dBA
