The OneConnect OCe11102-N is a high-performance, dual-port network adapter for 10 Gigabit Ethernet (10GbE) networks. A member of the Emulex OneConnect Universal Converged Network Adapter (UCNA) family, the OCe11102-N delivers industry-leading performance and scalability per watt.
OneConnect OCe11102-N adapters support protocol offloads for TCP/IP and TCP chimney offload to provide maximum bandwidth with minimum use of CPU resources. For virtualized server deployments, OneConnect protocol offloads enable more VMs per server, providing greater cost savings and optimized return on investment.
- Emulex OneConnect OCE11102-NM - network adapter - PCIe 2.0 x8 - 10GBase-SR x 2
- Network adapter
- Form Factor
- Plug-in card
- Interface (Bus) Type
- PCI Express 2.0 x8
- PCI Specification Revision
- PCIe 2.0
- Ports
- 10GBase-SR x 2
- 16.8 cm x 6.9 cm
- Cabling Type
- Ethernet 10GBase-SR
- Data Link Protocol
- 10 GigE
- Data Transfer Rate
- 10 Gbps
- TCP/IP, UDP/IP
- IEEE 802.1Q, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ae
- System Requirements
- FreeBSD, SUSE Linux Enterprise Server, Microsoft Windows Server, VMware ESX Server, CentOS, Ubuntu, Red Hat Enterprise Linux Server, Oracle Solaris
- Designed For
- QNAP TS-1079 Pro, TS-1079 Pro Turbo NAS, TS-1279U-RP Enterprise, TS-1279U-RP Turbo NAS, TS-879 Pro Turbo NAS, TS-879U-RP Turbo NAS, TS-EC1279U-RP Turbo NAS, TS-EC879U-RP Turbo NAS
- Network adapter
- Form Factor
- Plug-in card
- PCIe 2.0
- Ports
- 10GBase-SR x 2
- Connectivity Technology
- Wired
- Cabling Type
- 10 Gigabit Ethernet
- 10 Gbps
- TCP/IP, UDP/IP
- Flow control, VLAN support, IPv6 support, Quality of Service (QoS), Jumbo Frames support, TCP Chimney Offload support, IPv4 support, PXE support, Large Send Offload (LSO), Large Receive Offload (LRO), Receive Side Scaling (RSS)
- 2 x 10GBASE-SR - LC
- Compatible Slots
- 1 x PCI Express 2.0 x8
- C-Tick, CISPR 22 Class A, VCCI Class A ITE, EN55024, EN55022 Class A, EMC, ICES-003 Class A, RoHS, EN 60950-1, UL 60950-1 Second Edition, CSA C22.2 No. 60950-1-07, FCC Part 15 A, EN 60825-1, BSMI Class A, KCC Class A
- OS Required
- 16.8 cm
- 6.9 cm
- 0 °C
- 55 °C
- 5 - 95% (non-condensing)
- Designed For
