Teaching is quite an experience. Learning should be too. The ActivClassroom has always been all-encompassing. Now, it's an all-in-one interactive, collaborative, multimedia experience designed to capture the imagination of any type of learner - from the auditory to the visual to the kinaesthetic and everywhere between. The reason: the ActivBoard 300 Pro Range, a feature-rich interactive whiteboard that combines color, motion and interactivity with integrated sound and Dual-User functionality. Much more than your typical interactive whiteboard, the ActivBoard 300 Pro Range is a hub of activity. Built-in speakers and a discreet but powerful amplifier add stereo sound to any lesson. Available with fixed mount or motorized height-adjustable stands, short-throw projectors and a durable, classroom-ready surface mean everyone can come to the board. With built in dual-User capability and ActivInspire Professional Edition software included, teachers have access to tens of thousands of free lessons and resources at Promethean Planet.
Digitizing technology
Passive electromagnetic interface is encased behind robust melamine for technical reliability and durability. -
Screen surface
Low glare melamine provides an efficient projection surface.
- Promethean ActivBoard 387 Pro - interactive whiteboard - USB
- Interactive whiteboard
- Connectivity Technology
- Wired - USB
- 211 cm x 7.8 cm x 133 cm
- 27 kg
- Movement Detection Technology
- Electromagnetic
- Built-in stereo speakers, low-glare surface
- Cables Included
- 1 x USB cable - external - 5 m
- OS Required
- Microsoft Windows XP, Microsoft Windows Vista, Apple MacOS X 10.4.11 or later, Ubuntu 8.04
- 5-year warranty
- 211 cm
- 7.8 cm
- 133 cm
- 27 kg
Input Device
- Wired
- Interface
- USB
- Electromagnetic
- Active Area
- 186.5 cm x 117.5 cm
- 2 x USB
- Included Accessories
- Wallmount brackets, 4 x ActivPen
- Cables Included
- UL, FCC
- OS Required
- Limited warranty - 5 years
- 0 °C
- 50 °C
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
