Now there's a conference phone without cords that gives you the freedom to conference anywhere team collaboration is important - even in rooms where there are no phone lines.
With superior voice quality to the award winning SoundStation, proven 2.4 GHz wireless technology, added security of voice encryption, up to 24 hours of talk time, and the ability to dial through a cell phone, the SoundStation2W is the new standard for everyday conferencing.
SoundStation2W delivers voice quality that is twice as loud and provides twice the microphone sensitivity as the original SoundStation enabling clearer natural, two-way conversations. The secure and proven 2.4 GHz platform provides simple and robust wireless capability with any analog phone line. SoundStation2W is also the first phone that bridges cell phone convenience and Polycom voice quality. By connecting with a standard headset cable, users can dial through cell phones or transfer between handset and conference phone mode. With reliable 150 foot wireless roaming from the base station, wireless frequency hopping to avoid interference, and a long lasting Lithium-ion battery, the SoundStation2W truly meets today's needs for excellent voice quality and usage flexibility.
The SoundStation2W - designed to be used where you need it, because the conference room isn't enough!
Acoustic Clarity technology
Allow simultaneous natural conversation - the industry's best full duplex. -
Proven and secure wireless
2.4 GHz WDCT technology comes with voice encryption for added security. -
Long lasting battery
Charge once a week and go! Up to 24 hours talk time Lithium-ion battery with portable charger. -
Unparalleled flexibility
Cell phone connector is for a mode of conferencing when there are no phone lines available. -
Easy to use and install
Work like other Polycom conference phones, compatible with any analog line.
- Poly - Polycom SoundStation2W EX - cordless conference phone with caller ID
- Product Type
- Cordless conference phone with caller ID
- Cordless Phone Standard
- DECT
- Speakerphone
- Yes (digital duplex)
- Caller ID
- Call Services
- Caller ID, Call Hold
- Display
- LCD display - monochrome - Yes
- 1-year warranty
- Product Type
Phone Features
- DECT
- Call Services
- Caller ID Type
- Caller ID
- Max Handset Operating Distance
- 45 m
- Dialer Type
- Keypad
- Conference Call Capability
- Speakerphone
- Menu Operation
- Function Buttons
- Conference button, mute button, hold button, auto redial button
- Volume Control
- Firmware Upgradable
- Additional Features
- Noise reduction, on-hook dialling
Phone Memory
- Phone Directory Capacity
- 20 names & numbers
Display
- Display Information
- Battery status, signal strength
- Backlit
- Connections
- Cellular phone connection headset jack / sub-mini-phone 2.5mm , USB / mini-USB Type B , 2 x microphone jack , Audio line out / RCA
- Placing / Mounting
- Wall-mountable, table-top
- Included Accessories
- Power adapter
- UL, cUL, ICES-003, FCC Part 15.247, FCC Part 68
- Power adapter - external
- Battery
- 1 x battery
- Technology
- Rechargeable - Lithium Ion
- Included Qty
- 1
- Talk Time
- Up to 1440 min
- Standby Time
- Up to 160 h
- Recharge Time
- 8 hour(s)
- Audible Battery Alert
Dimensions & Weight (Base)
- 31.1 cm
- 36.8 cm
- 6.4 cm
- 0.86 kg
- Limited warranty - 1 year
BT ADSL Micro Filter RS | In Stock | £5.41 |
