The SoundPoint IP 331 is two-line SIP phone that delivers superb sound quality as well as a wide range of supported business telephony features. The SoundPoint IP 331 phone, with its dual-port 10/100 Ethernet switch for LAN and PC connection, presents a cost-effective solution for cubicle workers as well as call center operators who use a "hard" phone in conjunction with a "soft" client running on the PC.
Power Supply NOT included
Superb sound quality
The SoundPoint IP 331 phone features a full-duplex IEEE 1329 Type 1-compliant speakerphone with Polycom's legendary Acoustic Clarity Technology that delivers excellent sound quality and enables noise-free and echo-free conversations that are as natural as being there. -
Enterprise-grade feature set
The SoundPoint IP 331 phone delivers through an intuitive user interface a full feature set encompassing both traditional business telephony features such as call hold, park, pick-up, transfer, and three-way local conferencing, and more advanced capabilities such as shared call/bridged line appearance, hosts built-in XML micro browser, and distinctive call treatment. -
Efficient installation and provisioning
The SoundPoint IP 331 phone is engineered to make installation, configuration, and upgrades as simple and efficient as possible. The phones' standard base stand can be reversed to become a wall mount, eliminating the need for a separate accessory. Built-in IEEE 802.3af PoE circuitry and a dual-port Ethernet switch enable flexible deployment options and savings on cabling expenses.
- Poly - Polycom SoundPoint IP 331 - VoIP phone - 3-way call capability
- Product Type
- VoIP phone
- Main Features
- Integrated Ethernet switch
- VoIP Protocols
- SIP
- Voice Codecs
- G.729ab, G.711u, G.711a
- Lines Supported
- Multiline
- Intercom
- Speakerphone
- Yes (digital duplex)
- Caller ID
- Voice Mail Capability
- Call Services
- Voice Mail, Caller ID, Call Waiting, Call Forwarding, Call Transfer, Call Hold
- Display
- LCD display - monochrome
- Network Ports Qty
- 2 x Ethernet 10Base-T/100Base-TX
- 1-year warranty
- Product Type
- VoIP phone
Phone Features
- Call Services
- Dialer Type
- Keypad
- Dialer Location
- Base
- Conference Call Capability
- 3-way
- Intercom
- Speakerphone
- Menu Operation
- Function Buttons
- Speakerphone button, headset button, mute button, hold button
- Volume Control
- Ringer Control
- Indicators
- Visual ringer light
- Additional Functions
- Call timer, built-in clock, Intercom
IP Telephony
- Main Features
- VoIP
- VoIP Protocols
- SIP
- Voice Codecs
- Lines Supported
- Multiline
- Quality of Service
- IEEE 802.1Q (VLAN), IEEE 802.1p, Type of Service (ToS)
- IP Address Assignment
- DHCP, static
- Power Over Ethernet (PoE) Support
- Network Protocols
- TFTP, HTTP
- Network Ports Qty
- Voice Features
- Comfort noise generation (CNG), voice activity detection (VAD), echo cancellation (ECN)
- Network Features
- Network Address Translation (NAT)
Display
- Display Location
- Base
- Display Resolution
- 102 x 33 pixels
- Display Information
- Date, time
- Display Languages
- Danish, Slovenian, English, German, French, Italian, Norwegian, Portuguese, Polish, Swedish, Russian, Spanish, Dutch, Japanese, Chinese, Korean
- Connections
- Headset jack / sub-mini-phone 2.5mm
- Hearing Aid Compatible
- Placing / Mounting
- Wall-mountable, table-top
- Cables Included
- Network cable
- Included Accessories
- Phone base
- C-Tick, VCCI Class B ITE, GOST, CISPR 22 Class B, EN 61000-3-2, EN 61000-3-3, EN55022 Class B, ICES-003 Class B, EN 61000-6-1, AS/NZS 60950-1, CCC, EN55024 Class B, RoHS, IEC 60950-1, EN 60950-1, CSA C22.2 No. 60950-1-03, ANATEL, FCC CFR47 Part 15 B
Dimensions & Weight (Base)
- 625 g
- Limited warranty - 1 year
