Boost your enterprise's productivity with the NVIDIA NVS 310 by PNY dual-display professional graphics solution. This graphics board provides a reliable hardware and software platform to enable fast, cost-effective integration, deployment, and support across large enterprises. The NVS 310 board features DisplayPort 1.2, NVIDIA Mosaic technology, and NVIDIA NVIEW desktop management software, and can drive up to two 30-bit displays at resolutions up to 2560 x 1600 at 60 Hz. Plus, NVS 310 is designed with the ideal balance of performance and power to meet the needs of today's most demanding business user.
Fast DDR3 graphics memory
It is delivers high throughput to simultaneously play stunning HD video on each connected display. -
Intelligent Power Management
NVIDIA Power Management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability. -
NVIDIA CUDA
NVIDIA CUDA provides a development environment t and tool suite that unleash capabilities to solve various visualization challenges. -
Low-profile and flexible form factor
Simplifies IT administration and deployment throughout an enterprise. Regardless of desktop system or the display type NVS 310 has the ability to fit into any existing installations without being disruptive. -
Ultra-quiet fansink
Whisper-quiet 22 dba idle, 22.4 dba maximum at room temperature. -
Dual DisplayPort connectors
Supports ultra-high resolution panels up to 2560 x 1600 at 30 bpp - enabling maximum range, resolution, refresh rate, and color depth designed to support the display technologies. DisplayPort 1.2 multi-streaming allows daisy chaining of compatible display or attachment via DisplayPort 1.2 compliant hubs. -
NVIDIA high definition video technology
NVIDIA high definition video technology is the combination of high-definition video processors that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include, high-quality scaling, spatial temporal de-interlacing and high quality HD video playback - with low CPU utilization and power consumption. -
Multi-display experience with NVIDIA Mosaic technology
Mosaic technology enables seamless taskbar spanning as well as transparent scaling of any application across up to 8 displays.
- NVIDIA NVS 310 by PNY - graphics card - Quadro NVS 310 - 512 MB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- NVIDIA Quadro NVS 310
- Memory
- 512 MB DDR3
- CUDA Cores
- 48
- Memory Interface
- 64-bit
- Max Resolution
- 2560 x 1600
- Max Resolution Details
- DVI: 1920 x 1200 at 60 Hz / DisplayPort: 2560 x 1600 at 60 Hz
- Max Monitors Supported
- 2
- 2 x DisplayPort , 2 x DVI-D (Single-Link) - with adapter
- API Supported
- DirectX 11, OpenCL, DirectCompute, OpenGL 4.1
- 14.5 cm x 6.9 cm
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Bus Type
- Graphics Engine
- CUDA Cores
- 48
- Max Resolution
- 2560 x 1600 at 60 Hz
- 2
- API Supported
- NVIDIA Unified Driver Architecture (UDA), Nvidia CUDA technology, NVIDIA Mosaic, Nvidia Power Management technology, Shader Model 5.0, HDCP
- Size
- 512 MB
- Technology
- DDR3 SDRAM
- Bus Width
- 64-bit
- Bandwidth
- 14 GBps
- OS Required
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits) SP3, Oracle Solaris
- Min RAM Size
- 1 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- CD-ROM
- 19.5 Watt
- Included Accessories
- Low-profile bracket
- Cables Included
- 2 x DisplayPort-DVI adapter
- Software Included
- Drivers & Utilities, Nvidia nView Desktop Management Software
- 14.5 cm
- 6.9 cm
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £13.17 |
