The NVIDIA NVS 300 high resolution, multi-display business graphics solution, designed for small and standard form factor systems, delivers reliable hardware and software for a stable business environment. Tested on leading business applications, NVS 300 is capable of driving two VGA, single link DVI, DisplayPort or HDMI displays. With NVIDIA Mosaic and NVIDIA nView technologies built in, you can span and efficiently manage your entire Windows desktop across multiple displays.
Intelligent Power Management
NVIDIA Power Management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability. -
NVIDIA CUDA
CUDA's parallel computing architecture enables dramatic increases in computing performance by harnessing the power of the GPU (graphics processing unit). NVS 300 contains 16 CUDA parallel computing cores compatible with all CUDA accelerated applications. -
Ultimate image quality
NVIDIA NVS graphics product delivers the industry's good image quality, sharpness and pixel tracking for both analog and digital LCDs, DLPs and plasma displays with resolutions up to 2560 x 1600. -
Low-profile and flexible form factor
Simplify IT administration and deployment throughout an enterprise. Regardless of desktop system (standard tower PC. workstation, small form factor system) or the display type (LCD, DLP, plasma) NVS 300 has the ability to fit into any existing installations without being disruptive. -
High resolution display support
Drive ultra high resolution panels using integrated display technologies, producing phenomenal photorealistic image quality from a range of display connectors. Support two simultaneous displays, including single-link DVI, DisplayPort, VGA or HDMI. -
Dual DisplayPort (with audio)
Support ultra-high-resolution panels (up to 2560 x 1600 at 30bpp) - enabling maximum range, resolution, refresh rate, and color depth designed to support the display technologies. -
NVIDIA high definition video technology
NVIDIA high definition video technology is the combination of high-definition video processors and software that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content.
- NVIDIA Quadro NVS 300 by PNY - graphics card - Quadro NVS 300 - 512 MB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- Memory
- 512 MB DDR3
- Max Resolution
- 2048 x 1536
- Max Monitors Supported
- 2
- VGA (DMS-59)
- Package Type
- Retail
- Environmental Standards
- ENERGY STAR Qualified
- 3-year warranty
- Bus Type
- Graphics Engine
- Max Resolution
- 2048 x 1536
- 2
- VGA (DMS-59)
- NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, fanless heatsink, Nvidia CUDA technology, NVIDIA Mosaic
- Size
- 512 MB
- Technology
- DDR3 SDRAM
Video Output
- Supported Display Graphics
- QXGA (2048x1536), WUXGA (1920 x 1200), 2560x1600
- OS Required
- Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits)
- Included Accessories
- Low-profile bracket, full-height bracket
- Cables Included
- 1 x DMS-59 to 2 x VGA cable
- Software Included
- Drivers & Utilities, Nvidia nView Advanced Desktop Software
- Package Type
- Retail
- ENERGY STAR Certified
- Limited warranty - 3 years
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
