PNY NVIDIA QUADRO NVS 310 1GB DDR3 64-bit PCI-E X16 DUAL DisplayPort
Quicklinx: BWFKWS00 Mfr#: VCNVS310DP-1GB-PB
Boost your enterprise's productivity with the NVIDIA® NVS™ 310 dual-display professional graphics solution. This graphics board provides a reliable hardware and software platform to enable fast, cost-effective integration, deployment, and support across large enterprises. Each NVS 310 board features DisplayPort 1.2, NVIDIA Mosaic™ Technology, and NVIDIA NVIEW desktop management software, and can drive up to two 30-bit displays at resolutions up to 2560x1600 at 60Hz. This allows business professionals to maximize productivity by increasing their desktop real estate and leveraging advanced application-management tools. Plus, every NVS 310 is tested on leading business applications and designed with the ideal balance of performance and power to meet the needs of today's most demanding business user.
NVIDIA power management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability. PNY provides unsurpassed service and commitment to its professional graphics customers offering: 3-Year Warranty, pre and post-sales support, dedicated NVS Field Application Engineers and direct tech support hotlines. In addition, PNY delivers a complete solution including the appropriate adapters, cables, brackets, Software installation disc and documentation to ensure a quick and successful install.
  • Fast DDR3 graphics memory
    It is delivers high throughput to simultaneously play stunning HD video on each connected display.
  • Intelligent Power Management
    NVIDIA Power Management technology reduces overall system energy costs. It intelligently adapts the total power utilization of the graphics subsystem based on the applications being run by the end user. This power optimized design helps reduce Total Cost of Ownership (TCO) and increase reliability.
  • NVIDIA CUDA
    NVIDIA CUDA provides a development environment t and tool suite that unleash capabilities to solve various visualization challenges.
  • Low-profile and flexible form factor
    Simplifies IT administration and deployment throughout an enterprise. Regardless of desktop system or the display type NVS 310 has the ability to fit into any existing installations without being disruptive.
  • Ultra-quiet fansink
    Whisper-quiet 22 dba idle, 22.4 dba maximum at room temperature.
  • Dual DisplayPort connectors
    Supports ultra-high resolution panels up to 2560 x 1600 at 30 bpp - enabling maximum range, resolution, refresh rate, and color depth designed to support the display technologies. DisplayPort 1.2 multi-streaming allows daisy chaining of compatible display or attachment via DisplayPort 1.2 compliant hubs.
  • NVIDIA high definition video technology
    NVIDIA high definition video technology is the combination of high-definition video processors that delivers unprecedented picture clarity, smooth video, accurate color, and precise image scaling for SD and HD video content. Features include, high-quality scaling, spatial temporal de-interlacing and high quality HD video playback - with low CPU utilization and power consumption.
  • Multi-display experience with NVIDIA Mosaic technology
    Mosaic technology enables seamless taskbar spanning as well as transparent scaling of any application across up to 8 displays.
NVIDIA NVS 310 by PNY - graphics card - NVS 310 - 1 GB
Graphics card - low profile
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA NVS 310
1 GB DDR3
CUDA Cores
48
Memory Interface
64-bit
Max Resolution
2560 x 1600
Max Monitors Supported
2
2 x DisplayPort
API Supported
DirectX 11, OpenCL, DirectCompute, OpenGL 4.1, OpenACC
14.5 cm x 6.9 cm
Environmental Standards
ENERGY STAR Qualified
3-year warranty
Bus Type
PCI Express 2.0 x16
Graphics Engine
NVIDIA NVS 310
CUDA Cores
48
Max Resolution
2560 x 1600 at 60 Hz
2
2 x DisplayPort
API Supported
Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia GigaThread technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Mosaic, Shader Model 5.0, Dolby Digital Plus, Nvidia 3D Vision Pro, Dual-stream Hardware Acceleration, GPU Tessellation, Multi-Stream Technology, linear pulse-code modulation (LPCM) support, HDCP
Size
1 GB
DDR3 SDRAM
Bus Width
64-bit
Bandwidth
14 GBps
Linux, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Oracle Solaris, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits)
19.5 Watt
Low-profile bracket
Software Included
Display drivers, Nvidia nView Desktop Management Software
14.5 cm
6.9 cm
ENERGY STAR Certified
Limited warranty - 3 years
BWFK C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £13.17
