The NVIDIA Quadro K420 delivers power-efficient 3D application performance and capability. 1 GB of DDR3 GPU memory with fast bandwidth enables you to create complex 3D models, and a flexible single-slot and low-profile form factor makes it compatible with even the most space and power-constrained chassis. Plus, an all-new display engine drives up to four displays with DisplayPort 1.2 support for ultra-high resolutions like 3840 x 2160 at 60 Hz with 30-bit color.
Designed and built specifically for professional workstations, NVIDIA Quadro GPUs power more than 200 professional applications across a broad range of industries including manufacturing, media and entertainment, sciences, and energy. Professionals trust them to realize their most ambitious visions - whether its product design, visualization and simulation, or spectacular visual storytelling - and get results to market faster.
- NVIDIA Quadro K420 - graphics card - Quadro K420 - 1 GB
- Graphics card - low profile
- Bus Type
- PCI Express 2.0 x16
- Graphics Engine
- Memory
- 1 GB DDR3
- CUDA Cores
- 192
- RAMDAC
- 400 MHz
- Memory Interface
- 128-bit
- Max Resolution
- 3840 x 2160
- Max Resolution Details
- DVI: 2560 x 1600 at 60 Hz / DisplayPort: 3840 x 2160 at 60 Hz / VGA: 2048 x 1536 at 85 Hz
- Max Monitors Supported
- 2
- DVI-I (dual link) , DisplayPort , DVI-D (Single-Link) - with adapter , VGA - with adapter
- API Supported
- OpenCL, DirectCompute, DirectX 11.2, OpenGL 4.5
- 16 cm x 6.89 cm
- 3-year warranty
- Bus Type
- Graphics Engine
- CUDA Cores
- 192
- RAMDAC
- 400 MHz
- Max Resolution
- 3840 x 2160 at 60 Hz
- 2
- API Supported
- Nvidia SLI Multi-GPU Technology, NVIDIA Unified Driver Architecture (UDA), Nvidia nVIEW Multi-Display Technology, Nvidia CUDA technology, Nvidia 3D Vision technology, Nvidia Scalable Geometry Engine, NVIDIA Parallel DataCache, NVIDIA Mosaic, Deep Color technology, Hardware Video Decode Acceleration, Shader Model 5.0, Nvidia 3D Vision Pro, FXAA, SMX technology, Full-Scene Anti-Aliasing (FSAA), GPU Tessellation, Large Framebuffers with Ultra-Fast Bandwidth, Nvidia Fast Approximate Antialiasing Technology (FXAA), Multi-stream hardware H.264 encoder, Nvidia Quadro Mosaic Technology, Bindless Textures, Nvidia Temporal Anti-Aliasing Technology (TXAA), HDCP
- Size
- 1 GB
- Technology
- DDR3 SDRAM
- Bus Width
- 128-bit
- Bandwidth
- 29 GBps
- OS Required
- SunSoft Solaris, Linux, Microsoft Windows Vista / 7 / 8 / 8.1
- Min RAM Size
- 2 GB
- Min Hard Drive Space
- 200 MB
- Additional Requirements
- DVD-ROM
- 41 Watt
- Included Accessories
- Full-height bracket
- Cables Included
- 1 x DisplayPort-DVI adapter , 1 x DVI-VGA adapter
- Software Included
- Drivers & Utilities
- 16 cm
- 6.89 cm
- Limited warranty - 3 years
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
