Take on today's challenging, graphics-intensive games without missing a beat. The GeForce GTX 1070 graphics card delivers the incredible speed and power of NVIDIA Pascal - the most advanced GPU ever created - for truly revolutionary gaming and VR performance.
The GeForce GTX 1070 comes with ultra-fast FinFET technology and supports DirectX 12 features. This means you can count on an amazing experience in every application - including performance in AAA and immersive VR Ready games that's up to 3X faster than with previous-generation GPUs.
Get the power to drive next-generation displays, including VR, ultra-high-resolution, and multiple monitors. And bring more realism to every game with NVIDIA GameWorks technologies that offer a true cinematic experience and amazing new image-capture to share your game. All with the lowest latency and plug-and-play compatibility with leading VR headsets.
- PNY GeForce GTX 1070 - graphics card - GF GTX 1070 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1070
- Memory
- 8 GB GDDR5
- Core Clock
- 1506 MHz
- Boost Clock
- 1683 MHz
- CUDA Cores
- 1920
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Interfaces Details
- DVI , 3 x DisplayPort , HDMI
- API Supported
- DirectX 12, OpenGL 4.5, Vulkan
- 25.2 cm x 11.2 cm
- 3-year warranty
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1506 MHz
- Boost Clock
- 1683 MHz
- CUDA Cores
- 1920
- VR Ready
- Max Resolution
- 7680 x 4320 at 60 Hz
- API Supported
- Nvidia CUDA technology, Nvidia SLI ready, NVIDIA G-Sync ready, NVIDIA GameStream, NVIDIA GameWorks, Nvidia GeForce GTX VR Ready, NVIDIA GPU Boost 3.0, simultaneous multi-projection, NVIDIA Ansel, HDCP
- Size
- 8 GB
- Technology
- GDDR5 SDRAM
- Bus Width
- 256-bit
- Bandwidth
- 8 GBps
- OS Required
- Linux, FreeBSD (32-bit), Microsoft Windows 7 / 8 / 8.1 / 10
- Additional Requirements
- 8 pin PCI Express power connector
- 150 Watt
- RoHS, REACH
- 25.2 cm
- 11.2 cm
- Limited warranty - 3 years
