Poly Plantronics Spare Battery for Savi W740/W440 Wireless Headset
Quicklinx: 7SGZWS00 Mfr#: 84598-01
The Plantronics Replacement Battery for the Savi 740/440 Headset is a great choice for uninterrupted desk phone communication. Users can effortlessly charge the spare battery using a USB deluxe charger or a deluxe charging cradle. This headset accessory is specially engineered to last for a longer time between charges when used with compatible devices.
  • Headset battery fits Plantronics Savi 440 and 740 models perfectly
  • Compact form factor and lightweight design for added convenience
  • Can be used as a spare or to replace an old or faulty battery
  • 3.7V 140mAh 0.5Wh Li-ion Rechargeable Battery Pack
Product Dimensions:
0.1 x 0.1 x 0.1 cm ; 9 g
Compatible with:
Plantronics Savi W440, Savi W440/M, Savi W740, Savi W740/M, Savi W745 & Savi WH500 Wireless Headsets
Poly battery
Savi W440, W440-M, W740, W740/A, W740/A-M, W740-M
Headset
Poly Savi W440, W440-M, W740, W740/A, W740/A-M, W740-M
