The ingeniously simple Discovery 975 offers a custom blend of elegance and advanced technologies to keep you connected clearly, comfortably, and easily. A striking, minimalist design offers the simplicity of one-touch controls, while dual-mic AudioIQ and WindSmart technologies keep your conversations clear, even in harsh conditions.
The genius of simplicity
You have enough to think about without having to add an earpiece to your worries. The genius of the Discovery 975 is in its simplicity. Everything about this earpiece is designed to keep you connected comfortably, elegantly, clearly, and easily - so you never have to think about it. -
Elegance and comfort
A strikingly minimalist design defines the Discovery 975. From the subtle white indicator light that just flashes once when the earpiece is powered on, to the one-touch button that gives you control over powering it and answering/ending calls. A dedicated volume control doubles as a mute button for even more convenience. -
Advanced sound technologies
Beneath the sleek exterior of the Discover 975 are the advanced technologies that keep your calls clear and your voice sounding natural, even in a noisy automobile.
- Poly - Plantronics Discovery 975 - headset
- Product Type
- Headset - Bluetooth - wireless
- Recommended Use
- Portable electronics
- Headphones Form Factor
- Ear-bud monaural
- Connectivity Technology
- Wireless
- Wireless Technology
- Bluetooth
- Bluetooth Version
- Bluetooth 2.1 EDR
- Sound Output Mode
- Mono
- Active Noise Canceling
- Microphone
- Boom
- Controls
- Mute, volume
- Designed For
- Sonim XP1301 CORE NFC
- Product Type
- 8 g
- Recommended Use
- Max Operating Distance
- 10 m
Audio Output
- Ear-bud monaural
- Wireless
- Bluetooth
- Bluetooth Version
- Bluetooth 2.1 EDR
- Bluetooth Profiles
- Hands-Free Profile (HFP), Headset Profile (HSP)
- Sound Output Mode
- Mono
Microphone
- Boom
Remote Control
- Controls
- Mute, volume
Wireless Link
- Transmission Range
- 10 m
- Included Accessories
- Protective Charging Case, headphones earpads
- Power Device
- Power adapter - external
- Battery
- Headset battery rechargeable
- Run Time (Up To)
- 5 hour(s)
- Standby Time
- 168 hours
- Designed For
