Your basket is empty
Philips E-line - LCD display - TFT - widescreen - 1920 x 1080 - 250 cd/m2 - 5 ms
Quicklinx: 7NPWWS00 Mfr#: 227E3LSU/00
Discontinued, only used stock available
You can experience awesome LED pictures with natural colors. The elegant design with translucent blue bezel and SmartImage Lite makes it a great choice!
The Full HD screen has the widescreen resolution of 1920 x 1080p. This is the highest resolution of HD sources for the best possible picture quality. It is fully future proof as it supports 1080p signals from all sources, including the most recent like Blu-ray and advanced HD game consoles. The signal processing is extensively upgraded to support this much higher signal quality and resolution. It produces brilliant flicker-free progressive scan pictures with superb brightness and colors.
Philips E-line 227E3LSU - LED monitor - 21.5"
LED-backlit LCD monitor - 21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Full HD 1920 x 1080 at 60 Hz
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 20000000:1 (dynamic)
Response Time
5 ms
Colour Support
16.7 million colours
Input Connectors
DVI-D, VGA
Display Position Adjustments
Tilt
Glossy, black/blue
53.4 cm x 21.6 cm x 40.8 cm
3.7 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, UL, TUV GS, BSMI, GOST, cUL, SASO, SEMKO, TUV Ergo, PSB, DDC/CI, RoHS, Lead-Free, WEEE, TCO Certified Edge
Display Type
Diagonal Size
21.5"
Aspect Ratio
Widescreen - 16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms
Vertical Refresh Rate
75 Hz
Horizontal Refresh Rate
83 kHz
Horizontal Viewing Angle
176
Vertical Viewing Angle
170
Backlight Technology
WLED
OSD Languages
Chinese (simplified), English, German, French, Italian, Portuguese, Russian, Spanish, Turkish
Sync on Green, sRGB colour management, HDCP, SmartImage Lite, Touch Control
Glossy, black/blue
53.4 cm x 21.6 cm x 40.8 cm - with stand
3.7 kg
VGA , DVI-D
Mechanical
Tilt
Tilt Angle
25
MTBF
30,000 hour(s)
Power Supply
Internal
18.5 Watt
Power Consumption Stand by / Sleep
0.5 Watt
Dimensions & Weight Details
With stand - width: 53.4 cm - depth: 21.6 cm - height: 40.8 cm - weight: 3.7 kg , Without stand - width: 53.4 cm - depth: 4.1 cm - height: 33.6 cm - weight: 3.5 kg
20 - 80%
