Philips 243V5LHSB/00 24" 1920x1080 DVI VGA HDMI Monitor
Quicklinx: BYZKWS00 Mfr#: 243V5LHSB/00
16:9 Full HD display for crisp, detailed images
Picture quality matters. Regular displays deliver quality, but you expect more. This display features enhanced Full HD 1920 x 1080 resolution. With Full HD for crisp detail paired with high brightness, incredible contrast and realistic colours, expect a true-to-life picture.
SmartContrast for rich black details
SmartContrast is a Philips technology that analyses the contents you are displaying, automatically adjusting colours and controlling backlight intensity to dynamically enhance contrast for the best digital images and videos or when playing games where dark hues are displayed. When Economy mode is selected, contrast is adjusted and backlighting fine-tuned for just-right display of everyday office applications and lower power consumption.
HDMI-ready for Full HD entertainment
An HDMI-ready device has all the required hardware to accept High-Definition Multimedia Interface (HDMI) input. An HDMI cable enables high-quality digital video and audio to be transmitted over a single cable from a PC or any number of AV sources (including set-top boxes, DVD players, A/V receivers and video cameras).
LED technology for vivid colours
White LED's are solid state devices which light up to full, consistent brightness faster saving startup time. LED's are free from mercury content, which allows for eco-friendly recycling and disposal process. LED's allow for better dimming control of the LCD backlight, resulting in a super high contrast ratio. It also gives superior colour reproduction thanks to consistent brightness across the screen.
Easy display performance tuning with SmartControl Lite
SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc with the mouse.
Mercury Free eco-friendly display
Philips monitors with LED backlighting are free from Mercury, one of the most toxic natural substances, which affects humans and animals. This reduces the environmental impact of the display throughout its lifecycle, from manufacturing to disposal.
  • SmartControl Lite
    SmartControl Lite is the next generation 3D icon-based GUI monitor control software. This allows the user to fine-tune most parameters of the monitor like Colour, Brightness, screen calibration, Multimedia, ID management etc. with the mouse.
  • SmartContrast
  • Mercury Free
  • 16:9 Full HD display
  • HDMI Ready
Philips V-line 243V5LHSB - LED monitor - Full HD (1080p) - 23.6"
LED-backlit LCD monitor - 23.6"
Energy Class
Class F
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
19.5 W
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 10000000:1 (dynamic)
Response Time
5 ms (typical), 1 ms (grey-to-grey with overdrive)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, VGA
Display Position Adjustments
Tilt
Voltage
Textured black, black hairline
55.1 cm x 22 cm x 42 cm
3.66 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, FCC Class B certified, BSMI, GOST, SASO, SEMKO, PSB, DDC/CI, RoHS, Lead-Free, ISO 9241-307, WEEE, cETLus
Display Type
Energy Class
Class F
40 kWh
Diagonal Size
23.6"
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.272 mm
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
Vertical Refresh Rate
56 - 75 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
OSD Languages
Hungarian, Czech, Chinese (traditional), Chinese (simplified), Ukrainian, English, German, French, Italian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Japanese, Korean, Iberian Portuguese
Sync on Green, sRGB colour management, SmartContrast, 4:3 in Wide, Mercury free
55.1 cm x 22 cm x 42 cm - with stand
3.66 kg
VGA , HDMI (HDCP) , DVI-D (HDCP)
Mechanical
Tilt
Tilt Angle
-5/+20
VESA Mounting Interface
100 x 100 mm
MTBF
30,000 hour(s)
Input Voltage
19.5 W
20 kWh/1000h
Power Consumption (Typical)
18.59 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.3 Watt
On / Off Switch
No
Included Software
Philips SmartControl Lite
Apple MacOS X, Microsoft Windows 7, Windows 8
Dimensions & Weight Details
With stand - width: 55.1 cm - depth: 22 cm - height: 42 cm - weight: 3.66 kg , Without stand - width: 55.1 cm - depth: 5.2 cm - height: 34.4 cm - weight: 3.22 kg
Sustainability Information
ENERGY STAR Certified
20 - 80%
Accessories (5)
BYZK StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £143.67
BYZK StarTech.com Articulating Monitor Arm In Stock £132.69
BYZK StarTech.com Dual Monitor Stand In Stock £91.00
BYZK StarTech.com TV/Monitor Arm - Wallmount In Stock £82.52
BYZK StarTech.com Monitor Arm - Heavy Duty In Stock £93.49
Other bundles (1)
BYZK C2G 2m HDMI to DVI-D Digital Video Cable In Stock £11.38
