These versatile, ready to install mount models offer the convenience of installation to the ceiling or the wall and provide drop length options without the need of additional accessories. These mount models provide the first true comprehensive projector mounting solution in a single package.
- Peerless PARAMOUNT Ceiling/Wall Projector Mount with Adjustable Extension PPB - mounting kit - Tilt & Swivel - for projector - black
- Product Type
- Mounting kit (Tilt & Swivel)
- Mounting Components
- Extension column, ceiling plate, mounting adapter, horizontal adjuster
- Adjustable Width
- 16.5-42 cm
- Adjustable Depth
- 16.5-42 cm
- Adjustable Height
- 42.5-65.2 cm
- 1.7 kg
- Recommended Use
- Projector
- Max Load Weight
- 22.6 kg
- Material
- Cold-rolled steel
- Black
- 5-year warranty
- Adjustable Width
- 16.5-42 cm
- Adjustable Depth
- 16.5-42 cm
- Adjustable Height
- 42.5-65.2 cm
- 1.7 kg
- Material
- Cold-rolled steel
- Black
AV Furniture
- Mounting kit
- Design
- Tilt & Swivel
- Recommended Use
- Projector
- Max Load Weight
- 22.6 kg
- Scratch-resistant
- Limited warranty - 5 years
