Panasonic KV-S1026C Document Scanner
Quicklinx: 9KYDWS00 Mfr#: KV-S1026C-U
  • Windows 8 (32/64 bits)
The KV-S1026C on the other hand is aimed to meet more specific business needs within healthcare and banking, for example in receptions for administration purposes. It offers an abundance of unique features which other compact scanners don't, including the 'double feed skip' button which allows double feeds to enable the scanning of documents such as envelopes and pages with sticky notes, whilst scanning at a speed of up to 30 pages per minute in black and white and 20 pages per minute in color.
In the healthcare environment, the KV-S1026C is ideal as it allows for the scanning of a variety of documents; from identity cards to test results such as electrocardiograms, as it is able to scan papers as thin as 20 g/m2 as well as embossed cards. The KV-S1026C also meets banking needs through its ability to collate documents within customer information files including ID, documentary proof, loan contracts and legal documents. Giving account managers desktop scanners such as the KV-S1026C certainly helps to speed up the process of digitalizing and collating documents, and maximize the digital scanned image quality and therefore the file legibility.
Panasonic KV-S1026C-U - document scanner - desktop - USB 2.0
Document scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Max Supported Document Size
216 x 2540 mm
Input Type
Optical Resolution
600 dpi
Max Document Scan Speed
30 ppm (mono) / 20 ppm (colour)
Max Document Size
216 mm x 2540 mm
Automatic Duplexing
Supported Document Type
Plain paper
Document Feeder Type
Automatic
Document Storage Capacity
50 sheets
Microsoft Windows 7, Microsoft Windows XP SP3 or later, Microsoft Windows Vista (32/64 bits) SP2 or later, Windows 8 (32/64 bits)
30.3 cm x 17.7 cm x 13.7 cm
2.7 kg
Environmental Standards
ENERGY STAR Qualified
Interface Type
USB 2.0
216 x 2540 mm
Scanner
Input Type
Optical Resolution
600 dpi
Automatic Duplexing
Max Document Scan Speed B/W
30 ppm
Max Document Scan Speed Colour
20 ppm
Scanner Speed Details
30 ppm - portrait B&W - A4 - 200 dpi , 60 ipm - duplex - portrait B&W - A4 - 200 dpi , 20 ppm - portrait colour - A4 - 200 dpi , 40 ipm - duplex - portrait colour - A4 - 200 dpi
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 2540 mm
Plain paper
Automatic
50 sheets
USB 2.0 - Type B
1 x USB cable
ENERGY STAR Certified
External power adapter
Power Consumption Operational (Standby)
17 Watt (4.5 Watt)
Software Included
Drivers & Utilities, Image Capture Plus
30.3 cm
17.7 cm
13.7 cm
2.7 kg
10 °C
35 °C
20 - 80%
