A horizontal soundbar that sits neatly on a shelf or as part of a home entertainment stack, it can be transformed in to a 2.0 system simply by pulling apart the speakers, and replacing the central base with two separate vertical stands; one for each of the two speakers. The stands are adjustable which means they can be angled to suit your own set-up preference.
But it’s not just a neat modular design – Varsa also delivers impressive performance across all frequencies thanks to its 2 high-sensitivity drivers. The right speaker features touch-sensitive power on/standby, volume control and mute functions.
- OTONE Varsa - sound bar
- Product Type
- Sound bar
- Speaker Type
- Active
- Continuous Power
- 20 Watt
- Frequency Response
- 90 - 20000 Hz
- Amplifier
- Integrated
- Speaker Details
- Sound bar - stereo x 2 - 10 Watt - 90 - 20000 Hz - active
- 57 cm x 8.6 cm x 8.7 cm
- 1.3 kg
- 2-year warranty
- Product Type
- Sound bar
- Design Features
- Modular design
Speaker System
- Speaker Type
- Active
- Continuous Power
- 20 Watt
- 90 - 20000 Hz
- Signal-To-Noise Ratio
- 70 dB
- Amplifier
- Integrated
- Controls
- Mute, power on/off, volume
- Additional Features
- Touch sensor buttons, transformable into a stereo system
Speaker System Details
- Speaker Details
- Sound bar - stereo x 2 - 10 Watt - 90 - 20000 Hz CFR - active
- Driver Details
- Speaker: 2 x full-range driver - 1.57"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor, audio cable, 2 speaker stands, horizontal sound bar base
- Power Source
- AC power adapter
- 57 cm
- 8.6 cm
- 8.7 cm
- 1.3 kg
- Limited warranty - 2 years
