Stilo is a 2.1 speaker system that will transform your home PC or AV set-up. The sharp-featured satellite speakers house twin 2" high-sensitivity divers, and are mounted on adjustable stands which can be angled to suit your own set-up preference. The chunky 5¼" long-excursion Vortex Drive subwoofer completes this 2.1 system giving a clean and rich, distortion-free sound, while you can get that all-important bass to just the right level with the control on the back of the sub. This 2.1 system also comes with a wired remote control for both power and volume adjustment. It also offers an auxiliary line-in and headphone jack for when you need to keep your music to yourself.
- OTONE Stilo - speaker system
- Product Type
- Speaker system - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 40 Watt
- Frequency Response
- 70 - 20000 Hz
- Amplifier
- Integrated
- 3.65 kg
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 40 Watt
- 70 - 20000 Hz
- Signal-To-Noise Ratio
- 70 dB
- Amplifier
- Integrated
- Controls
- Power on/off, volume
Speaker System Details
- Driver Details
- Satellite speaker: 2 x full-range driver - 2"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 5.25" - Vortex Drive system
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm) , Audio line-in (RCA x 2) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- AC power adaptor, audio cable, wired remote control with headphones connector
- Power Source
- AC power adapter
- 3.65 kg
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 6.5 cm x 10.6 cm x 25.3 cm , Subwoofer: 22 cm x 23 cm x 21.1 cm
