The satellites are perfectly balanced by the sideward-firing 5" vortex drive subwoofer, creating clear and full, distortion-free sound - making for a great value speaker system that delivers top quality audio.
As well as being amongst the best computer speakers in terms of their price/performance, Exo gives you the rich bass that music lovers demand from a 2.1 speaker system.
- OTONE Exo - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 40 Watt
- Frequency Response
- 70 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 2 x satellite speaker 10 Watt , 1 x subwoofer 20 Watt
- Power
- AC 230V (50 Hz)
- 4.38 kg
- 2-year warranty
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 40 Watt
- 70 - 20000 Hz
- Signal-To-Noise Ratio
- 70 dB
- Amplifier
- Integrated
- Controls
- Power on/off, volume
- Speakers Included
- 2 x satellite speaker - 10 Watt - wired , 1 x subwoofer - 20 Watt - wired
- Driver Details
- Satellite speaker: high/midrange driver - 2"
- Driver Details (2nd speaker)
- Subwoofer: subwoofer driver - 5" - Vortex Drive system
- Connector Type
- 2 x audio line-in (mini-phone stereo 3.5 mm) , Headphones (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, wired remote control with headphones connector
- Power Source
- AC power adapter
- Voltage Required
- AC 230V (50 Hz)
- 4.38 kg
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 8.2 cm x 5.9 cm x 17.2 cm , Subwoofer: 16 cm x 19 cm x 19 cm
- Limited warranty - 2 years
