Highly stylized for the Smartphone generation, Accento is designed for life on the move: its rechargeable batteries offer 8 to 10 hours of listening power and the speakers weigh just 200g. You can even strap it to your wrist - or use the fold-out stand to place it on a table or desk.
What's more, you can insert the micro SD card directly from your Smartphone so you can listen to music without interrupting your conversation. So if you've got a rechargeable MP3 player, get some rechargeable portable speakers to go with it: Accento - the best rechargeable speakers for the money.
- OTONE Accento - speaker - for portable use
- Product Type
- Speaker - for portable use
- Media Content Source
- Flash memory card
- Speaker Type
- Active
- Continuous Power
- 6 Watt
- Frequency Response
- 120 - 18000 Hz
- Amplifier
- Integrated
- Speaker Details
- Speaker - stereo x 2 - 3 Watt - 120 - 18000 Hz - 4 Ohm - active
- Power Options
- USB charging
- Battery
- Speaker battery rechargeable - Lithium Ion
- 13.7 cm x 3.8 cm x 5.7 cm
- 200 g
- 2-year warranty
- Product Type
- Flash memory card
Speaker System
- Speaker Type
- Active
- Continuous Power
- 6 Watt
- 120 - 18000 Hz
- Signal-To-Noise Ratio
- 50 dB
- Amplifier
- Integrated
- Controls
- Power on/off, volume, play/pause, next track, previous track
- Additional Features
- Built-in stand
Speaker System Details
- Speaker Details
- Speaker - stereo x 2 - 3 Watt - 120 - 18000 Hz CFR - 4 Ohm - active
- Driver Details
- Speaker: 2 x full-range driver - 1.57"
- Connector Type
- Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- Audio cable, wrist strap, mini-USB cable
- Power Source
- Battery
- Options
- USB charging
- Rechargeable - Lithium Ion
- Run Time (Up To)
- 10 hour(s)
- 13.7 cm
- 3.8 cm
- 5.7 cm
- 200 g
- Limited warranty - 2 years
