OTONE Accento Rechargeable Portable Speaker
Quicklinx: B1YLWS00 Mfr#: 11010101
Highly stylized for the Smartphone generation, Accento is designed for life on the move: its rechargeable batteries offer 8 to 10 hours of listening power and the speakers weigh just 200g. You can even strap it to your wrist - or use the fold-out stand to place it on a table or desk.
What's more, you can insert the micro SD card directly from your Smartphone so you can listen to music without interrupting your conversation. So if you've got a rechargeable MP3 player, get some rechargeable portable speakers to go with it: Accento - the best rechargeable speakers for the money.
OTONE Accento - speaker - for portable use
Speaker - for portable use
Media Content Source
Flash memory card
Speaker Type
Active
Continuous Power
6 Watt
Frequency Response
120 - 18000 Hz
Amplifier
Integrated
Speaker Details
Speaker - stereo x 2 - 3 Watt - 120 - 18000 Hz - 4 Ohm - active
Power Options
USB charging
Speaker battery rechargeable - Lithium Ion
13.7 cm x 3.8 cm x 5.7 cm
200 g
Flash memory card
Speaker System
Speaker Type
Active
Continuous Power
6 Watt
Frequency Response
120 - 18000 Hz
Signal-To-Noise Ratio
50 dB
Amplifier
Integrated
Controls
Power on/off, volume, play/pause, next track, previous track
Additional Features
Built-in stand
Speaker System Details
Speaker Details
Speaker - stereo x 2 - 3 Watt - 120 - 18000 Hz CFR - 4 Ohm - active
Driver Details
Speaker: 2 x full-range driver - 1.57"
Connector Type
Audio line-in (mini-phone stereo 3.5 mm)
Audio cable, wrist strap, mini-USB cable
Power Source
Options
USB charging
Rechargeable - Lithium Ion
Run Time (Up To)
10 hour(s)
13.7 cm
3.8 cm
5.7 cm
200 g
