Optoma DS348 5VGA WUXGA 3000 Lumens 3D Projector
Quicklinx: C3YJWS00 Mfr#: 95.71P02GC1E
Project bright vibrant presentations effortlessly any time on day. Designed for meeting rooms and classrooms, the DS348 boasts sRGB accurate true to life color reproduction, long lamp life and energy-saving features to provide you with a low overall cost of ownership. This projector is easy to connect to with two HDMI inputs, MHL, USB-power and a built-in speaker.
  • Amazing colors
    For vibrant, natural looking images, Optoma projectors incorporate BrilliantColor multi-color processing technology.
  • USB-power
    Use the USB-?ower to power an HDMI dongle.
  • Eco+
    Eco+ technology brings together high contrast, improved lamp life and energy saving features that are easy to use while reducing power consumption.
  • Energy saving
    Using the specially designed lamp modes, you can reduce the power consumption. Each mode also has a positive effect on the lamp life, while lowering the total cost of ownership and reducing maintenance.
  • High contrast
    Add more depth to your image with a high contrast projector; with brighter whites and ultra-rich blacks, images come alive and text appears crisp and clear - ideal for business and education applications.
  • Full 3D
    Optoma projectors can display true 3D content from almost any 3D source, including 3D Blu-ray players, 3D broadcasting. Support for 144 Hz rapid refresh rate provides ultra-smooth flicker free images.
  • MHL
    Turn your projector into a smart display by connecting your smartphone or tablet with a single cable using MHL; now you can view presentations and documents, stream videos and share photos on the big screen.
  • Integrated speaker
    The built-in speaker offers excellent audio support. Easy to set up without the need for costly external speakers
  • Eco AV mute
    Stay in control of your presentation with Eco AV mute. Direct your audience's attention away from the screen by blanking the image when no longer needed. This also reduces the power consumption, further prolonging the life of your lamp.
  • Quick resume
    This feature allows the projector to be instantly powered on again, if it is accidentally switched off.
  • Auto Power Off
    There may be instances when the projector is left running when not in use. To help save energy, the Auto Power Off feature automatically turns off the projector after a set period of time if it is not being used.
Optoma DS348 - DLP projector - portable - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Built-in Devices
Speaker
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1
Resolution
SVGA (800 x 600)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
195 Watt
Bulb life cycle
Up to 10000 hour(s) - economic mode
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
225 Watt
29.8 cm x 23 cm x 9.65 cm
2.17 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Microdisplay
DarkChip 3
Brightness
3000 ANSI lumens
Contrast Ratio
20000:1
Image Size
71 cm - 773 cm
Projection Distance
1 m - 12 m
Throw Ratio
1.94 - 2.16:1
Uniformity
75 %
Resolution
SVGA - SVGA (800 x 600) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
4:3
Colour Support
Max Sync Rate (V x H)
85 Hz x 91.1 kHz
Bulb type
195 Watt
Bulb life cycle
OSD Languages
Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
BrilliantColor, 16:9 aspect ratio support, Auto Power Off, Eco+ technology, ProJect Green, MHL compliance
Lens
Lens Aperture
F/2.4-2.53
Zoom Type
Manual
Zoom Factor
1.1x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-40 / +40
Video Input
Video Interfaces
HDMI
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
2 Watt
1 x HDMI input , 1 x Mobile High-Definition Link (MHL) / HDMI , 1 x audio line-out - mini-phone 3.5 mm , 1 x USB (power only) - 4 pin USB Type A (power only)
Remote control
Security Features
Security lock slot (cable lock sold separately), password protection, security bar
RoHS
Power Source
AC
225 Watt
Power Consumption Stand by
0.5 Watt
29.8 cm
23 cm
9.65 cm
2.17 kg
5 °C
0 - 85%
29 dB
