Utilizing the latest DLP technology, the DH1011 delivers exceptional crystal-clear Full HD native resolution and immersive 3D visuals. Producing a stunningly bright image with perfectly balanced vivid color, crystal clarity and exceptional light and shade detail only possible with a high contrast projector. The DH1011 is perfect for projecting a broad range of applications including technical, advertising media and medical uses where detail matters.
Installed or on the move using the included carry bag, the versatile DH1011 has a powerful on-board 16W stereo speaker, HDMI connectivity and energy saving features including ECO mode and auto power off saving you both time and money for hassle-free, long-lasting projection.
Lights on viewing
The DH1011 produces fantastic images even when the lights are on with 3500 Lumens. Designed to be used in ambient light the high brightness DH1011 can be used without even dimming the lights. -
Full HD 1080p
Sharper more detailed projection with 1920 x 1080p pixels, perfect for watching Blu-ray movies without downscaling or compression. -
Full 3D
Using the inherent speed of DLP technology, The Optoma DH1011 Full 3D projector can display true 3D content form almost any 3D display device. -
Dynamic black
Dynamic black smoothly adjusts the lamp output automatically, based on the brightness information of each frame; to create a stunning 13,000:1 contrast ratio. Bright scenes are crisp and clear, while dark scenes remain detailed with deep blacks which gives exceptional light and shade detail. -
Amazing colors
The DH1011 incorporates BrilliantColor multi-color processing technology to bring stunning, vibrant color to your screen. You can even fine tune colors for ultimate precision. -
Audio WOW - SRS WOW HD surround sound
Embrace the WOW factor with SRS WOW HD surround sound audio processing to create a more natural audio experience with a deep, rich bass response. Easy to set up without the need for costly external speakers the DH1011 offers exceptional sound quality with powerful on-board 16W stereo audio.
- Optoma DH1011i - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 18000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 4000 hour(s)
- Video Input
- RGB, component video
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 233 Watt
- 31.5 cm x 22.4 cm x 10.2 cm
- 2.55 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 18000:1
- Image Size
- 106 cm - 775 cm
- Projection Distance
- 1.5 m - 10 m
- Throw Ratio
- 1.48 - 1.62:1
- Uniformity
- 80 %
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
- BrilliantColor, AMX Device Discovery, Auto Power Off, Eco+ technology, MHL compliance
Lens
- Focus Type
- Manual
- Lens Aperture
- F/2.5-2.67
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -30 / +30
Video Input
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, MHL
- Video Modes
Speakers
- Integrated
- Output Power / Channel
- 10 Watt
- 1 x Mobile High-Definition Link (MHL) / HDMI - 19 pin HDMI Type A , 1 x HDMI - 19 pin HDMI Type A , 1 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x serial RS-232 (management) , 1 x USB , 1 x USB (power only) - 4 pin USB Type A
- Included Accessories
- Wireless remote control
- Mounting Kit
- Optional
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- RoHS
- Power Source
- AC
- Voltage Required
- 233 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 22.4 cm
- 10.2 cm
- 2.55 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission
- 29 dB
