The all-digital Optoma DH1009 is ideal for use in conference rooms, training rooms, classrooms, houses of worship and digital signage applications. Delivering a powerful bright image with a remarkable contrast ratio and DynamicBlack technology, the Optoma DH1009 will captivate your audience with its crystal clear HD resolution image with astounding shadow detail and rich vibrant colors. Equipped with an impressive list of standard features, the DH1009 will help you deliver winning presentations.
- Optoma DH1009 - DLP projector - portable - 3D
- DLP projector - 1080p
- 3D Capable
- Yes (3D glasses sold separately)
- Built-in Devices
- Speaker
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 20000:1
- Resolution
- Full HD (1920 x 1080)
- Native Aspect Ratio
- 16:9
- Colour Support
- 1.07 billion colours
- Bulb type
- 190 Watt
- Bulb life cycle
- Up to 5000 hour(s) - normal mode , Up to 6000 hour(s) - economic mode
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 233 Watt
- 31.5 cm x 22.4 cm x 11.4 cm
- 2.45 kg
- 3D Capable
- Built-in Devices
- Speaker
Projector
- Brightness
- 3200 ANSI lumens
- Contrast Ratio
- 20000:1
- Image Size
- 106 cm - 767 cm
- Projection Distance
- 1.5 m - 10 m
- Throw Ratio
- 1.48 - 1.62:1
- Uniformity
- 80 %
- Resolution
- Full HD - Full HD (1920 x 1080)
- 16:9
- Colour Support
- Max Sync Rate (V x H)
- 85 Hz x 91.146 kHz
- Bulb type
- 190 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- OSD Languages
- Danish, Hungarian, Czech, Indonesian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Greek, Turkish, Arabic, Romanian, Japanese, Korean
- BrilliantColor, 16:9 aspect ratio support, 4:3 aspect ratio support, Auto Power Off, MHL compliance
Lens
- Lens Aperture
- F/2.5-2.67
- Zoom Type
- Manual
- Zoom Factor
- 1.1x
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -40 / +40
Video Input
- Video Interfaces
- HDMI
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 2 x HDMI - 19 pin HDMI Type A , 1 x 3D Sync out - 3 PIN mini-DIN , 1 x audio line-out - mini-phone stereo 3.5 mm
- Included Accessories
- Wireless remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection, security bar
- RoHS
- Power Source
- AC
- Voltage Required
- 233 Watt
- Power Consumption Stand by
- 0.5 Watt
- 31.5 cm
- 22.4 cm
- 11.4 cm
- 2.45 kg
- 5 °C
- 40 °C
- 0 - 85%
- Sound Emission (Economic Mode)
- 26 dB
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
