Your basket is empty
OCZ Technology 500W CoreXStream Series Power Supply
Ideal Power Upgrade!!
Quicklinx: 8174WS00 Mfr#: OCZ-CSX500W-UK
Power Rating: 500Watt
129 in stock
£26.99 ex VAT
£32.38 inc VAT
OCZ CoreXStream Series 500 Watt Power Supply
The OCZ CoreXStream Series is the ideal value upgrade to satisfy essential computing needs with worry-free compatibility. The PSU is kept supremely cool with a load-controlled 120mm fan to remain quiet under load, and provides ample cable lengths for your home system application. Featuring up to 80% efficiency under typical load environments, this power supply remains rock solid and stable under pressure. Combined with a sleek look and elegant black powdercoat finish, you can be rest assured this PSU will look as good as it performs in your home office system.
  • Ideal value option for home users and upgraders on a budget
  • Ample cable lengths to suit various applications and system configurations
  • Continuous output rated at 30°C ambient temperature
  • 80% efficient at typical loads
  • Dual +12V rails for efficient power distribution in your system.
  • Compliant with ATX12V v2.2 standard for worry-free compatibility
  • A temperature and load controlled 120mm fan for whisper quiet operation
  • ErP compliant for low power usage in standby
  • Active Power Factor Correction (PFC) to effectively regulate input voltage
  • Heavy-duty protection circuitry, (over-voltage, over-power, and short circuit) for protecting your valuable components
  • Safety Approvals: CUL, CE, CB, FCC Class B, TÜV, CCC, C-tick
  • Elegant black powdercoat finish for a sleek and simple look
  • 3-Year OCZ PowerSwap Warranty, no endless return-for-repair loops
Connectors
  • 1 x 20+4-pin ATX
  • 1 x 4+4-pin ESP/12V CPU
  • 1 x 6+2-pin PCI-E
  • 1 x 6 pin PCI-E
  • 2 x 4-pin Peripheral
  • 4 x 5-pin SATA
  • 1 x FDD
  • AC Input 230Vrms, 5A, 50Hz
  • Output Voltage +3.3V +5V +12V1 +12V2 -12V +5VSB
  • Max. Load 24A 15A 25A 20A 0.3A 2.5A
  • Max. Combined 120W 444W 3.6W 12.5W
  • Total Output 500W
  • Dimensions: 5.9"(W) x 3.4"(H) X 5.5"(L); 150mm(W) x 86mm(H) x 140mm(L)
  • MTBF: 100,000 Hours
OCZ CoreXStream - power supply - 500 Watt
Power supply - active Power Factor Correction (PFC) - internal
Specification Compliance
ATX12V 2.2
1.6 kg
United Kingdom
Input Voltage
AC 230 V
Power Capacity
500 Watt
Output Connector(s)
1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin EPS12V with detachable 4 pin ATX12V section , 1 x 8 pin PCI Express power with detachable 2 pin section , 1 x 6 pin PCI Express power , 2 x 4 PIN internal power , 4 x 15 pin Serial ATA power , 1 x 4 PIN mini-power connector
Cooling System
120 mm fan
15 cm x 14 cm x 8.6 cm
3 years warranty
ATX12V 2.2
United Kingdom
Input Voltage
AC 230 V
Frequency Required
50 Hz
Max Electric Current
5 A
Power Capacity
500 Watt
Circuit Protection
Circuit breaker
Output Current
+3.3V - 24 A , +5V - 15 A , +12V1 - 25 A , +12V2 - 20 A , -12V - 0.3 A , +5VSB - 2.5 A
Efficiency
80%
MTBF
100,000 hours
Cooling System
120 mm fan
Over voltage protection, overpower protection, dual 12V rails, short-circuit protection
FCC Class B certified, TUV, C-Tick, cUL, CB, CCC, ErP Ready
3 years warranty
Service & Support Details
Limited warranty - 3 years
15 cm
14 cm
8.6 cm
1.6 kg
Shipping Width
15.8 cm
Shipping Depth
18.7 cm
Shipping Height
16.5 cm
Shipping Weight
1.8 kg
Resources
The following resources are available for the OCZ Technology 500W CoreXStream Series Power Supply
Brand: OCZ Technology
Price Range Ex VAT: 0 - 50
