Don't retype your documents - convert them! OmniPage 18 is the fastest and most precise way to convert paper, PDF files, and even digital camera pictures into documents you can edit in your favorite PC applications. OmniPage 18 delivers unrivaled accuracy, speed, and innovative features.
As the industry-leading solution, OmniPage 18 delivers the most accurate document conversion available, turning paper and PDF files into electronic files you can edit, search, and share. In addition, OmniPage 18 ensures that your converted electronic documents look exactly like the original - complete with text, graphics, columns, and tables.
All of this means OmniPage 18 will significantly reduce the amount of time spent converting important files, so you can focus on more important business goals.
Superior word accuracy
Transform words on paper and in images to accurate text for superior conversion and archiving. -
Maintain formatting
Converted documents look just like the original. -
Automation of emailed documents
Receive scanned papers or PDFs via Microsoft Outlook email. -
Intuitive user experience
Convert documents quickly with easy-to-use tools and flexible options. -
Language recognition
Process, edit and store documents from virtually anywhere in the world; the tool recognizes over 120 languages. -
One-click workflows
Use the built-in workflows or create your own to get recurring conversion jobs done easily and quickly. -
Photo conversion
Convert any picture or photo into a readable format for mobile devices and electronic book readers.
- Kofax OmniPage Standard (v. 18) - box pack - 1 user
- Product Type
- Box pack
- Category
- Utilities - OCR software
- Version
- 18
- Licence Qty
- 1 user
- Platform
- Windows
- Language
- English
- Distribution Media
- CD-ROM
- Category
- Product Type
- Box pack
- Version
- 18
- Platform
- Windows
- CD-ROM
- Language
- English
- Min Supported Colour Depth
- 16-bit (64k colours)
Licencing
- Licence Qty
- 1 user
- Supported OS
- Microsoft Windows Vista (32/64 bits) SP2, Microsoft Windows XP SP3, Microsoft Windows 7 (32/64 bits)
- Additional Requirements
- Sound card, CD-ROM, speakers, scanner, digital camera, graphics card, XGA monitor, Internet connection
