The NETGEAR Powerline AV 200 Wireless-N Extender Kit creates a wireless hotspot in an area of your home where you can't get wireless coverage using your homes existing electrical wiring. It offers easy, Plug and Play setup and provides fast wired and wireless speeds for the most demanding applications. Reliable and secure, it is ideal for both professional and personal Internet use, providing Wireless-N speed for simultaneous downloads, voice and music, and online gaming.
Extend your network
Extend Internet access throughout your home for wireless devices like laptops and Wi-Fi enabled smart phones and wired devices such as desktop PC's, gaming consoles and set-top boxes. -
Plug-and-Play
Sets up in minutes, no need to configure or install software. -
High-speed connections
High speed enables Internet applications such as multiplayer gaming. -
Push-and-secure
Secures the powerline network connection with the touch of a button, no need to remember passwords. -
Pick-a-plug
Automatically tests the connection at any electrical outlet to ensure the highest possible performance. -
Push 'N' connect
Ensures a quick and secure wireless network connection. -
NETGEAR green features
Power on/off buttons, automatic powerline shutdown when not in use and 80% recycled packaging.
- NETGEAR Powerline XAVNB2001 - powerline adapter kit - 802.11b/g/n - wall-pluggable
- Powerline adapter kit
- Enclosure Type
- Wall-pluggable
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV)
- Data Transfer Rate
- 200 Mbps
- IEEE 802.3, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, Wi-Fi Protected Setup
- 11.2 cm x 7.4 cm x 4.5 cm
- 245 g
- Localisation
- United Kingdom
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- 200 Mbps
- IEEE 802.3, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, HomePlug AV, Wi-Fi Protected Setup, Plug and Play, RoHS, WEEE, REACH
- Status Indicators
- Power, status
- 1 x HomePlug AV , 1 x 10Base-T/100Base-TX - RJ-45
- Power Device
- Internal power supply
- Included Accessories
- 200 Mbps Powerline AV Ultra network adapter
- Cables Included
- 2 x network cable - 2 m
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- 11.2 cm
- 7.4 cm
- 4.5 cm
- 245 g
