The NETGEAR RangeMax Dual Band Wireless-N Gigabit Router delivers the ultimate in wireless performance for home and small business networking. With twice the available bandwidth, separate Wireless-N access points for media/gaming and data, and concurrent dual band N, you will enjoy the most reliable wireless connections for HD media streaming, gaming, and maximum Internet bandwidth. Along with four gigabit Ethernet ports enabling maximum wired speeds, this full featured high performance router is an ideal solution for the connected home with multiple computers and network enabled gadgets running multiple applications at the same time.
Centralizing an external storage device and file sharing is easy. Simply connect your USB storage device to the back port of your Dual Band router, and every computer on your network can now access the USB Storage device, easily exchanging media, documents, music, and more. The dual band gigabit router prioritizes network traffic efficiently, ensuring high quality of experience for video streaming, VoIP, online gaming and other critical tasks.
- NETGEAR RangeMax WNDR3700 - wireless router - 802.11a/b/g/n (draft 2.0) - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Remote Management Protocol
- HTTP
- Firewall protection, Stateful Packet Inspection (SPI), DoS attack prevention, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
- Environmental Standards
- ENERGY STAR Qualified
- 22.3 cm x 15.3 cm x 3.1 cm
- 0.5 kg
- Microsoft Certification
- Compatible with Windows 7
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000 / ME / XP/ Vista
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- HTTP
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WPA-Enterprise, WPA2-Enterprise
- Authentication Method
- Radio Service Set ID (SSID)
- Processor
- MIPS 680 MHz
- RAM
- 64 MB
- Flash Memory
- 8 MB
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 8
- Power Device
- External power adapter
- ENERGY STAR Certified
- Included Accessories
- Vertical stand
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 22.3 cm
- 15.3 cm
- 3.1 cm
- 0.5 kg
- Limited warranty - 1 year
