The XS708T 10-Gigabit Ethernet Smart Managed Switch brings the second generation of 10-Gigabit Copper switching to SMBs. The XS708T is a powerful Smart Managed Switch that includes 8 ports of 10-Gigabit connectivity (8 copper with 2 shared combo copper/SFP+ Fiber ports). NETGEAR's 10-Gigabit Smart Managed Switches are purposely designed as a cost-effective way to provide 10G connections to 10G-capable servers and NAS (Network Attached Storage) systems. The XS708T provides comprehensive L2+/Layer 3 Lite features (including IPV6 management) allowing SMB customers to deploy virtualization, cloud-based services and applications like VoIP, video streaming and IP surveillance, which require higher reliability, speed, and performance. It can be used at the "center of a small business network" or as an aggregation/access switch in a larger organization. The XS708T is ideal for smaller workgroups that need high-bandwidth for sharing, collaborating, editing, and publishing high-density content like video or animation.
Comprehensive L2+ / Layer 3 Lite features
The ProSAFE 10G Smart Managed Switch provides comprehensive L2+ / Layer 3 Lite features in order to meet current and future needs on virtualization, converged networking and mobility. -
Smart IT, not big IT
Easy-to-use web browser-based management GUI makes setup and management simple. It features a standards-based technology, ensuring interoperability with any standards-based devices in the existing network, as well as dual firmware images, improving reliability and uptime to your network. -
10-Gigabit transition with BASE-T
10GBASE-T, like other BASE-T technologies, uses the standard RJ-45 Ethernet jack. It is backward compatible, auto-negotiating between higher and lower speeds - thereby not forcing an all-at-once network equipment upgrade.
- NETGEAR Smart XS708T - switch - 8 ports - smart - rack-mountable
- Switch - 8 ports - L3 Lite - smart
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 10 Gigabit Ethernet
- Ports
- 8 x 10GBase-T + 2 x shared 10 Gigabit SFP+
- Performance
- Switching fabric bandwidth: 160 Gbps , Forwarding performance (64-byte packet size): 119 Mpps
- Capacity
- ACL: 100 , Virtual interfaces (VLANs): 512 , IGMP groups: 512 , IPv4 routes: 32 , IPv6 routes: 32 , Priority queues per port: 8 , ARP entries: 738 , DHCP snooping entries: 8000
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- Static IPv4 routing, static IPv6 routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP, HTTPS
- Flow control, ARP support, VLAN support, IGMP snooping, Syslog support, DoS attack prevention, port mirroring, DiffServ support, Weighted Round Robin (WRR) queuing, store and forward, MAC address filtering, Broadcast Storm Control, IP address filtering, Unicast Storm Control, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, Dynamic ARP Inspection (DAI), reset button, LACP support, LLDP support, Port Security, DHCP client, Energy Efficient Ethernet, Multicast VLAN Registration (MVR), Strict Priority Queuing (SPQ), 2MB packet buffer, Class of Service (CoS), 802.1x authentication, Type of Service (ToS), DiffServ Code Point (DSCP) support, cable test, layer 2+ switching
- IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3an, IEEE 802.3az
- 44 cm x 20.4 cm x 4.3 cm
- 2.61 kg
- Localisation
- Latin America, North America, Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Ports
- Performance
- Capacity
- 16K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- TLS 1.0, SSL 3.0
- Authentication Method
- RADIUS, TACACS+
- Processor
- Cortex-A9: 600 MHz
- RAM
- 512 MB
- Flash Memory
- 256 MB
- Status Indicators
- Port transmission speed, power, link/activity, fan
- 8 x 10GBase-T RJ-45 , 2 x 10GBase-X SFP+ , 1 x USB 2.0 management
- Power Device
- Internal power supply
- 49.5 Watt
- Included Accessories
- Rubber feet
- Rack Mounting Kit
- Included
- MTBF
- 276,197 hours
- cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, CCC, FCC Part 15 A, C-Tick Class A, SCC, VCCI Class A, TLS v1.2, TLS v1.0
- Localisation
- Software Included
- Drivers & Utilities
- 44 cm
- 20.4 cm
- 4.3 cm
- 2.61 kg
- 0 °C
- 50 °C
- 90% (non-condensing)
- Min Storage Temperature
- -10 °C
- Max Storage Temperature
- 70 °C
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
