ProSafe Wireless-N Access Point
- Wireless-N speeds up to 10x the coverage and 15x the speed of 802.11g networks
- Improved coverage and 10x greater speed than Wireless-G
- Simultaneously supports 802.11n and 802.11g devices
- Advanced Enterprise security features: WPA2, rogue AP detection and 802.1x
- with RADIUS support
- Integrated Power over Ethernet (IEEE 802.3af PoE) lowers deployment costs
- Supports IEEE 802.3af PoE for easy placement in optimal locations—desktop,
- wall-mount or ceiling
- Deploy over large areas as a bridge or a repeater both in point-to-point and
- point-to-multipoint with Wireless Distribution System (WDS)
- Comprehensive SNMP functionality for advanced network management
- Mounting kit provides for wall or ceiling placements
- Internal antenna factory-optimized for maximum RF performance
- Antenna take-offs enable optional accessory antenna attachment
- NETGEAR Wireless-N Access Point WNAP320 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Capacity
- Maximum number of users: 64
- OS Required
- UNIX, Apple MacOS, Linux, Microsoft Windows 98/ME/2000/XP/Vista
- Power Over Ethernet (PoE) Supported
- PoE
- 25.4 cm x 25.4 cm x 5.5 cm
- 0.89 kg
- NETGEAR lifetime warranty
- 25.4 cm
- 25.4 cm
- 5.5 cm
- 0.89 kg
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI
- Frequency Band
- 2.4 GHz
- Capacity
- Status Indicators
- Port transmission speed, power, WLAN, LAN
- VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Multiple SSID support, wireless bridge mode
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
- Authentication Method
- Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID), Extensible Authentication Protocol (EAP)
- IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- Gain Level
- 5 dBi
- 1 x 1000Base-T - RJ-45 , 1 x management - DB-9 , 2 x aerial
- Cables Included
- 1 x network cable
- Mounting Kit
- Included
- PoE
- Power Device
- External power adapter
- Software Included
- Drivers & Utilities
- OS Required
