Your basket is empty
NetGear ProSafe 8 Port 10/100 Fast Ethernet PoE Switch
Customer rating: 5.0* (Write a review)
Quicklinx: 3MBJWS00 Mfr#: FS108PEU
Ports: 8
9 in stock
£73.71 ex VAT
£88.45 inc VAT
The ProSafe FS108P provides power and data from a single point, using Power over Ethernet (PoE) over a single Cat-5 cable. The eight Fast Ethernet ports can be used for any 10/100 Mbps link and four of these ports can supply industry-standard IEEE 802.3af power. Advanced auto-sensing algorithm gives power only to 802.3af end devices, so no need to worry about damaging proprietary PoE or non-PoE equipment. In addition, it discontinues the power when PoE devices are disconnected. Easy and reliable, the ProSafe FS108P automatically determines PoE requirements, speed, duplex, and cable type using AutoUplink.
The affordably priced ProSafe FS108P delivers PoE to any small business network that wants to simplify the installation of wireless access points and IP-based surveillance cameras. These devices are optimally installed on a ceiling or high on a wall, away from most electrical outlets. PoE eliminates the requirement for a dedicated electrical outlet to power these devices. This allows for flexibility in situating devices where AC power is difficult to access and lowers installation costs. Compact and flexible, the ProSafe FS108P is ideal for small business network that want to inexpensively use PoE to deploy wireless access points and IP-based network surveillance cameras.
  • Affordable Power over Ethernet switching
    The ProSafe FS108P provides power and data from a single point, using Power over Ethernet (PoE) over a single CAT5 cable. The eight Fast Ethernet ports can be used for any 10/100 Mbps link and four of these ports can supply industry-standard IEEE 802.3af power. Advanced auto-sensing algorithm gives power only to 802.3af end devices, so no need to worry about damaging proprietary PoE or non-PoE equipment. In addition, it discontinues the power when PoE devices are disconnected. Easy and reliable, the ProSafe FS108P automatically determines PoE requirements, speed, duplex, and cable type using Auto Uplink.
  • Flexible
    Choose to plug in up to eight Ethernet or Fast Ethernet devices and mix in up to four 802.3af IP-based devices like wireless access points or IP-based network surveillance cameras. Place these 802.3af-compliant devices where they belong - high up on walls and ceiling for maximum coverage - or anywhere else you need them. Power and data are carried over standard CAT5 cabling.
  • Plug and Play
    The standards-based ProSafe FS108P senses and adjusts for network speed and cabling type automatically, for easy integration into your existing 10/100 Ethernet network. For PoE, the switch automatically detects 802.3af-compliant devices, and supplies power as needed. Front panel LEDs keep you informed of switch and PoE status.
  • Quiet and compact
    Engineered for compact convenience, it features a 9-inch, durable metal case that is easily positioned on your desktop or a wall, using the included mounting hardware. The fan-less design quietly integrates with your small office environment.
  • Great value
    With data switching and Power over Ethernet integrated into one unit, the FS108P saves space, reduces cables and eliminates the requirement for dedicated electrical outlets - lowering installation costs, simplifying installation of PoE-capable devices, and eliminating the need for electricians or extension cords. All in all, a great benefit for a modest price.
NETGEAR ProSafe FS108P 8 Port 10/100 Desktop Switch with 4 Port PoE - switch - 8 ports - desktop
Switch - 8 ports
Enclosure Type
Desktop
Ports
8 x 10/100
Power Over Ethernet (PoE)
PoE
MAC Address Table Size
1K entries
Flow control, auto-sensing per device, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3af, IEEE 802.3x
23.5 cm x 10.3 cm x 2.7 cm
0.7 kg
Europe
NETGEAR lifetime warranty
Switch - 8 ports
Enclosure Type
Desktop
Ports
8 x 10/100
PoE
1K entries
Status Indicators
Link activity, port transmission speed, power, link OK, active
4 x 10Base-T/100Base-TX - RJ-45 , 4 x 10Base-T/100Base-TX - RJ-45 - PoE
Power adapter - external
44 Watt
23.5 cm
10.3 cm
2.7 cm
0.7 kg
Mounting Kit
Included
MTBF
190,000 hour(s)
C-Tick, VCCI Class B ITE, EN 60950, EN55024, EN55022 Class B, FCC Part 15 B
Europe
* Compared to buying items separately
Options (1)
3MBJ NetGear 3 Year HW Extended Warranty Category 1 In Stock £25.63
Customer reviews
Write a review for the NetGear ProSafe 8 Port 10/100 Fast Ethernet PoE Switch here!
5.0 2
£73.71
Does the job
Reviewed by . Review Posted 12/05/2009
5 5
Great little switch for the price. Works with our PoE IP Cameras attached to it and has never gone down since we have had it running (~3 months).
Compact and quiet and doesn't get too hot, which is always good.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Excellent
Reviewed by Anonymous Review Posted 08/12/2007
5 5
Great switch - does what it says in terms of data and has worked perfectly with several PoE devices I've tried it with.
Nicely built in a steel case, no fans so completely quiet, and a separate small 50v power supply to run the switch itself and any PoE kit attached.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
Type: Fast Ethernet
Ports: 8
Data Transfer Rate: 100Mbps
Brand: NetGear
Price Range Ex VAT: 50 - 100
