The ProSafe Gigabit stackable smart switch family is unique in delivering the scalability, reliability, and performance growing small and medium-sized businesses need in an affordable and easy-to-manage package. This stackable smart switch offers more flexibility and scalability that will make it easier and non-interruptive for growing businesses to expand their network capacity.
Stacking for scalability and high availability
The stackable smart switch uses 2 dedicated dual-purpose ports in the front of the switch for stacking or uplink. The stacking function offers a 10 Gbps, dual-ring, highly redundant stacking bus that carries intra-stack traffic and provide the highest level of resilience, forming a virtual chassis for easy management under a single IP address. -
Comprehensive and advanced feature sets
This stackable smart switch comes with a complete suite of advanced features for more robust security, higher quality of service and high availability. This switch is equipped with highly advanced features such as access control lists (ACL), static routing, rate limiting, IGMP snooping, and dynamic VLAN assignment among others to provide a small and medium-sized business with a network that is geared for growth and network applications. Friendly to converged network with voice and video, the stackable smart switch offers auto voice and auto video features that automatically configure QoS, security and VLAN settings for IP phones and IP cameras. -
IPv6 support
In order to accommodate the move by Internet service providers to IPv6 addresses, the Gigabit stackable smart switch expand the IPv6 support beyond management only to QoS, ACL and multicast. It means that your network will benefit from the IPv6 enhancements and is future-proofed.
- NETGEAR Gigabit Stackable Smart Switch GS728TPS (2nd Generation) - switch - 24 ports - Managed - rack-mountable
- Switch - 24 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 16 x 10/100/1000 (PoE) + 8 x 10/100/1000 (PoE+) + 4 x Gigabit SFP
- Power Over Ethernet (PoE)
- PoE
- Performance
- Bandwidth: 56 Gbps
- Capacity
- Virtual interfaces (VLANs): 256 , Static routes: 32 , ACL: 100
- MAC Address Table Size
- 16K entries
- Routing Protocol
- Static IP routing
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SNMP 2c, HTTP
- Flow control, power over Ethernet (PoE), VLAN support, IGMP snooping, DoS attack prevention, port mirroring, store and forward, Broadcast Storm Control, IPv6 support, full duplex mode, Multicast Storm Control, Unicast Storm Control, firmware upgradable, SNTP support, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, DHCP snooping, Access Control List (ACL) support, Quality of Service (QoS), RADIUS support, MLD snooping, PoE+, LLDP support, Link Aggregation Control Protocol (LACP), Energy Efficient Ethernet
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3at, IEEE 802.3az
- Power
- AC 120/230 V (47 - 63 Hz)
- 44 cm x 25.7 cm x 4.3 cm
- 3.9 kg
- Localisation
- Europe
- NETGEAR lifetime warranty
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- Capacity
- 16K entries
- Max Units In A Stack
- 6
- Routing Protocol
- Static IP routing
- RAM
- 128 MB DDR SDRAM
- Flash Memory
- 32 MB
- Status Indicators
- Port transmission speed, power, PoE, link/activity, fan
- 16 x 1000Base-T RJ-45 PoE , 8 x 1000Base-T RJ-45 PoE+ , 6 x SFP (mini-GBIC)
- Power Device
- Internal power supply
- Voltage Required
- 236 Watt
- Cables Included
- 1 x stacking cable
- Rack Mounting Kit
- Included
- C-Tick, EN 60950, EN55022, VCCI Class A ITE, EN55024, UL 60950, CB, CCC, FCC Part 15 A
- Localisation
- Europe
- Software Included
- Drivers & Utilities
- 44 cm
- 25.7 cm
- 4.3 cm
- 3.9 kg
- 0 °C
- 50 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
