NETGEAR ProSAFE 24-PORT 10/100 PoE Smart Switch with 4 Gigabit Ports
LIFETIME WARRANTY
Customer rating: 5.0* (Write a review)
Quicklinx: 4K93WS00 Mfr#: FS728TP-100EUS
NETGEAR ProSafe FS728TP, provides power and data using built-in IEEE 802.3af PoE on all 24 10/100 ports. In addition, the FS728TP offers advanced features such as Access Control Lists (ACL), 802.1x port authentication, enhanced QoS, rate limiting and IGMP Snooping, to provide a small and medium-sized business with a network geared for growth while providing scalability and reliability. An intuitive web-based management tool provides quick, easy deployment and configuration, making it ideal for deploying VoIP phones, access points and IP surveillance cameras.
NETGEAR FS728TP - switch - 24 ports - Managed - rack-mountable
Switch - 24 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 (PoE) + 2 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE
PoE Budget
192 W
Virtual interfaces (VLANs): 128 , Priority queues per port: 8 , Layer 2 multicast groups: 512
MAC Address Table Size
4K entries
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, HTTP, TFTP
Flow control, VLAN support, IGMP snooping, DoS attack prevention, port mirroring, Broadcast Storm Control, full duplex mode, Multicast Storm Control, Unicast Storm Control, WRED, STP support, RSTP support, MSTP support, DHCP snooping, TFTP support, ACL support, QoS, LACP support, LLDP support, DHCP client, 1MB packet buffer, Multicast filtering function, CoS, DoS, 4MB packet buffer, 802.1x authentication, VoIP support, DSCP support, administrator's password, BPDU
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3az
44 cm x 25.7 cm x 4.3 cm
3.57 kg
Europe
NETGEAR lifetime warranty
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE
PoE Budget
192 W
4K entries
Routing Protocol
Authentication Method
RADIUS, TACACS+
Status Indicators
Port transmission speed, power, PoE, link/activity, fan
24 x 100Base-TX RJ-45 PoE , 4 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Internal power supply
256 Watt
Rack Mounting Kit
Included
MTBF
237,497 hours
cUL, EN 60950, IEC950, UL 1950, EN55024, CSA 22.2 No. 950, EN55022 Class A, CISPR 22, EN50082-1, CCC, FCC Part 15 A, C-Tick Class A, VCCI Class A
Europe
44 cm
25.7 cm
4.3 cm
3.57 kg
50 °C
90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
95% (non-condensing)
Customer reviews
Write a review for the NETGEAR ProSAFE 24-PORT 10/100 PoE Smart Switch with 4 Gigabit Ports here!
Great Value PoE Layer 2 Switch
Reviewed by Gary. Review Posted 19/11/2007
We just started using the Netgear FS728TP switch to run some wireless access points using power of ethernet (PoE). All of the 24 fast ethernet ports support PoE automatically to devices that request it all over standard CAT5 ethernet cabling. You can mix normal devices (PCs/Printers) with PoE devices. The switch supports VLANS so we can separate public and private traffic on the same switch. SNMP support allows remote monitoring of all the important statistics and switch status and the easy to use web interface makes administration really easy with no hard to remember command line stuff.
The switch also supports port trunking, QoS and provides a port monitoring facility for network debugging. A really advanced feature set, great price and easy to use. We love it.
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Well recommended
Reviewed by Chris. Review Posted 15/10/2007
Although this switch does have fan noise, I would have to say that a switch of this class is designed more for cabinet mounting, not desktop use.
This is a switch that is great value for money - it will work right out of the box, providing power over ethernet to devices such as VoIP phones, Webcams, etc whilst also offering a vast array of configuration items for the more advanced user such as SNMP, Qos & VLans.
The build quality is excellent as well - this feels solid and includes rack mounting fixings as well.
Overall, a highly recommended switch
  • Overall 5*
  • Ease of use 5*
Can't hear you!
Reviewed by david. Review Posted 29/08/2007
High levels of fan noise with this switch which makes it unsuitable for an office environment.
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
