Get the advanced way to store, stream and protect your data with ReadyNAS. With the complete data protection and extensive storage, you can rest assured your photos, videos and music are safe with a few layers of protection. Access your data on the go with easy-to-use features and blazing-fast speeds.
Advanced backup and sync
Premier home storage backup and access for multiple users. Extensive storage, a powerful processor and large RAM. Automatic backup and on-the-go backup of photos from your phone. -
Stream and share photos, movies and music
Powerful media server. Fast reading and writing, maximize speeds while streaming and sharing. Simple drag and drop functionality makes accessing, saving and sharing easy. -
Different levels of data protection
Automatic multi-folder backup and RAID, which keeps the integrity of your data even in the event of hard drive failure. Exclusive snapshot technology keeps historical versions of data, to easily revert files if necessary. Bit rot protection defends against media degradation.
- NETGEAR ReadyNAS 204 - NAS server - 8 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 8 TB
- Max Supported Capacity
- 24 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 22.3 cm x 13.4 cm x 20.5 cm
- 4.02 kg ()
- Processor
- 1 x Cortex-A15 1.4 GHz (Dual-Core)
- Storage Controller
- 1 x RAID SATA 3Gb/s RAID RAID 0, 1, 5, 6, 10, JBOD
- Hard Drive
- 4 x 2 TB SATA 6Gb/s
- Networking
- 10Mb LAN, 100Mb LAN, GigE
- IP Cameras Supported
- 8
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- ReadyNAS OS 6.2
- System Requirements
- UNIX, SunSoft Solaris, Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Android, Microsoft Windows 7 (32/64 bits), Apple iOS, Microsoft Windows Server 2012, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 8 TB
- 24 TB
- 22.3 cm
- 13.4 cm
- 20.5 cm
- 4.02 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- RAM
- 2 GB
Storage Controller
- 1 x RAID
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6, RAID 10, JBOD
Hard Drive
- HDD - hot-swap - 3.5"
- Capacity
- 4 x 2 TB
- Interface Type
- SATA 6Gb/s
- Spindle Speed
- 7200 rpm
- Buffer Size
- 64 MB
- Data Link Protocol
- NTP, DHCP, Bonjour
- Remote Management Protocol
- SNMP 2, SNMP 3, SSH
- Network Services Compatibility
- Microsoft Active Directory (AD), Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- Dynamic IP address assignment, load balancing, VLAN support, wake on LAN (WOL), E-mail alert, LACP support, DHCP client, WebDAV server
- IEEE 802.3ad (LACP)
Security DVR
- 8
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap - 2.5" / 3.5"
- 2 x Ethernet 1000Base-T - RJ-45 , 3 x USB 3.0 , 1 x eSATA
- FCC Class B certified, RoHS, VCCI Class B
- Power Device
- External power adapter
- Voltage Required
- Power Provided
- 90 Watt
- ReadyNAS OS 6.2
- OS Required
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 5 - 95% (non-condensing)
