An Industry-first: Enterprise-class Solutions that Liberate SMB.
With unlimited snapshots, block-level replication, native deduplication, and flexible form factors, ReadyDATA brings affordable, easy-to-manage, high-end data solutions to businesses of all sizes.
Unlimited Snapshots
Welcome to Unlimited Snapshots for NAS. ReadyDATA gives you continuous data protection with unlimited block-based snapshots of your file system. Create and track multiple versions and restore any point of time with a single click. And admin couldn't be easier or more flexible: you can schedule automatic or manual Snapshots and restore Snapshot data from local admin GUI or native Windows File Explorer.
Block-Level Replication
Designing simple, cost-effective disaster recovery plans is easy with ReadyDATA cloud-managed, block-level replication. By sending only changed blocks for shares & LUNs, bandwidth demands and replication time are dramatically reduced. ReadyDATA also replicates unlimited snapshots along with files and data--complete copies of data sets from a specific point in time you can easily access and restore.
Read/Write Optimization
One way to balance performance, capacity, and costs is to combine SATA and SSD drives in one volume. ReadyDATA excels with these hybrid configurations--allowing you to configure write-optimized and read-optimized SSD drives to act as a performance cache and boost the performance of low-cost, high-capacity SATA drives.
High-Efficiency Storage
Efficiently managing rampant data growth is an vexing challenge. ReadyDATA smartly reduces storage capacity requirements with deduplication and compression. By shrinking backup data and removing globally common blocks of data as they are written, redundancy is eliminated from multiple backup jobs, and valuable capacity is saved.
ReadyDATA Hybrid Cloud
The new Cloud Replicate feature allows users to cut the office cord completely by using the ReadyDATA Hybrid Cloud. It makes replication from multiple sites--without being on site-- simple and powerful. The ReadyDATA Cloud-based Management portal offers easy block-level replication along with unlimited snapshots--from anywhere, at anytime.
Thin and Instant Provisioning
ReadyDATA virtualization gives you the critical flexibility to add capacity as needed--so no need to predetermine volume capacity and quotas ahead of time. ReadyDATA also provides thin provisioning for all volume types, making easier, smarter virtualization management a reality. ReadyDATA adds automatic--and on-the-fly--volume expansion, making overhead protection and capacity scaling both simple and powerful. This instant expansion capability allows for storage capacity expansion without downtime, wait time, or risk.
Virtual Networking
Dual 10GbE ports on the 5200 and virtual network interface support on all models ensure that even in I/O intensive virtual environments, network bottlenecks are a thing of the past. ReadyDATA also supports industry-standard file sharing protocols including iSCSI, CIFS, and NFS.
Superior Support and Outstanding Warranty
Behind every ReadyDATA device stands outstanding customer protection. NETGEAR's 5-year Warranty is Best-In-Breed and includes Drive Packs. And critical, next business day hardware replacement is delivered onsite and supported for 3 years.
Enterprise-class unified storage at a small business price
The ReadyDATA 5200 ships with a full suite of advanced features such as block-level replication, deduplication, and thin provisioning. Add expansion to at many as 180 TB and the dramatic perforce boost that comes from supporting a mix of SSD, SAS and SATA drives within a volume, and ReadyDATA redefines the concept of storage for small and medium businesses, remote offices/branch offices (ROBO), and departments within enterprise organizations. -
Scalable capacity
The ReadyDATA family of unified storage was built with the needs of a growing business in mind. ReadyDATA 5200 is 2U, 12-bay storage that supports 1 TB, 2 TB and 3 TB drives for a total of 36 TB capacity. Each ReadyDATA 5200 can support up to two expansion chassis, for a fully populated capacity of up to 180 TB. Also, new drives can be easily added while the system is running for seamless expansion on-the-fly. -
Peak performance
For meeting the differing needs of specific applications, ReadyDATA 5200 users can mix-and match SATA, near-line SAS, SAS, and SSD drives within volumes to provide a stunning boost to performance and flexible capacity. Dual 10GbE ports and virtual network interface support ensure that even in I/O intensive virtual environments, network bottlenecks are a thing of the past. ReadyDATA 5200 also supports industry-standard file sharing protocols including iSCSI, CIFS, and NFS. -
Advanced data management
With data volume growing faster than ever before, the need to find more efficient ways to store and manage data is crucial. Unlike enterprise-class storage from traditional vendors, a full set of advanced data management technologies come standard with every ReadyDATA 5200.
- NETGEAR ReadyDATA 5200 - NAS server
- NAS server
- Host Connectivity
- 10 Gigabit Ethernet
- Enclosure Type
- Rack-mountable - 2U
- Installed Devices / Modules Qty
- 0 (installed) / 12 (max)
- 43.7 cm x 64.8 cm x 8.9 cm
- 32.8 kg ()
- Processor
- 1 x Intel Xeon 2.66 GHz (Quad-Core)
- Storage Controller
- RAID RAID RAID 0, 1, 5, 6
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE, 10 GigE
- RAM
- 16 GB
- Power
- AC 120/230 V (50/60 Hz)
- Power Redundancy
- Storage Operating System
- NETGEAR ReadyDATA OS 1.0
- 5-year warranty
- NAS server
- Host Connectivity
- Enclosure Type
- Total Storage Capacity
- 0 GB
- 43.7 cm
- 64.8 cm
- 8.9 cm
- 32.8 kg ()
Processor / Memory
- Processors Installed
- Number of Cores
- Quad-Core
- RAM
- 16 GB
Storage Controller
- RAID - internal
- Max Storage Devices Qty
- 12
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 6
- Data Link Protocol
- DHCP
- Remote Management Protocol
- SNMP, HTTP, HTTPS
- Network Services Compatibility
- Microsoft Active Directory (AD), WINS, DHCP, Microsoft CIFS, Network File System (NFS), FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- Dynamic IP address assignment, DHCP support, load balancing, VLAN support, wake on LAN (WOL), E-mail alert, IPv6 support, event log, DHCP server, static IP mode, temperature sensor
- IEEE 802.3ad (LACP)
- Expansion Bays
- 12 (total) / 12 (free) x hot-swap
- Expansion Slots
- 2 x SFP+
- 2 x Ethernet 1000Base-T - RJ-45 , 2 x USB 2.0
- VCCI, C-Tick, CCC, FCC, RoHS, KCC, WEEE
- Included Accessories
- Rack mounting kit
- Power Device
- Internal power supply - hot-plug
- Installed Qty
- 2
- Max Supported Qty
- 2
- Power Redundancy
- Power Redundancy Scheme
- 1+1
- Voltage Required
- Power Provided
- 700 Watt
- Limited warranty - 5 years
- 0 °C
- 40 °C
- 20 - 80%
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
