NetGear ProSafe Wireless-N Access Point
LIFETIME WARRANTY
Quicklinx: 7VK4WS00 Mfr#: WNAP320-100UKS
  • IEEE 802.11n
  • Wireless-N speeds up to 10x the coverage and 15x the speed of 802.11g networks
  • Improved coverage and 10x greater speed than Wireless-G
  • Simultaneously supports 802.11n and 802.11g devices
  • Advanced Enterprise security features: WPA2, rogue AP detection and 802.1x
  • with RADIUS support
  • Integrated Power over Ethernet (IEEE 802.3af PoE) lowers deployment costs
  • Supports IEEE 802.3af PoE for easy placement in optimal locations—desktop,
  • wall-mount or ceiling
  • Deploy over large areas as a bridge or a repeater both in point-to-point and
  • point-to-multipoint with Wireless Distribution System (WDS)
  • Comprehensive SNMP functionality for advanced network management
  • Mounting kit provides for wall or ceiling placements
  • Internal antenna factory-optimized for maximum RF performance
  • Antenna take-offs enable optional accessory antenna attachment
NETGEAR Wireless-N Access Point WNAP320 - radio access point - Wi-Fi
Radio access point
External
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Maximum number of users: 64
UNIX, Apple MacOS, Linux, Microsoft Windows 98/ME/2000/XP/Vista
Power Over Ethernet (PoE) Supported
PoE
25.4 cm x 25.4 cm x 5.5 cm
0.89 kg
NETGEAR lifetime warranty
Radio access point
25.4 cm
25.4 cm
5.5 cm
0.89 kg
United Kingdom
External
Wireless
Remote Management Protocol
SNMP 1, Telnet, SNMP 2c, HTTP, SSH, CLI
Frequency Band
2.4 GHz
Status Indicators
Port transmission speed, power, WLAN, LAN
VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, wall mountable, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Multiple SSID support, wireless bridge mode
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, SSL, TLS, PEAP, TTLS, WPA, WPA2
Authentication Method
Secure Shell (SSH), RADIUS, Radio Service Set ID (SSID), Basic Service Set Identifier (BSSID), Extensible Authentication Protocol (EAP)
IEEE 802.11b, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11i, IEEE 802.11n
Aerial
Antenna
Internal
Antenna Qty
2
Gain Level
5 dBi
1 x 1000Base-T - RJ-45 , 1 x management - DB-9 , 2 x aerial
1 x network cable
Mounting Kit
Included
PoE
External power adapter
Software Included
Drivers & Utilities
