NetGear GS105PE-10000S ProSAFE 5-Port POE/PD Gigabit Plus Switch
LIFETIME WARRANTY
Quicklinx: B8SGWS00 Mfr#: GS105PE-10000S
Type: Gigabit Ethernet
Ports: 5
Data Transfer Rate: 1Gbps
Managed: Yes
POE: PoE+
£52.59 ex VAT
£63.10 inc VAT
Requires PoE (Power over Ethernet) to power the device
The NETGEAR GS105PE ProSafe Plus 5-Port Desktop Gigabit PoE Switch meets the growing needs of small businesses by providing fundamental network features that will help optimise the performance their networks.
On top of the Plug-n-Play Gigabit Ethernet connectivity, this NETGEAR GS105PE switch also offer essential networking features such as two (2) PoE ports, VLAN, QoS, IGMP Snooping, Link Aggregation (LAG), rate limiting and traffic monitoring.
This NETGEAR GS105PE ProSafe Plus Switch is an exceptional value for businesses looking to add intelligence to their network beyond what unmanaged switches can provide.
Prioritise Voice/Video
With the ability to set up and configure QoS, this NETGEAR GS105PE ProSafe Plus switch can detect different types of network traffic and assign the desired priority to latency-sensitive traffic, such as voice and video. This helps improve the delivery quality of related applications such as VoIP, multimedia broadcasting, and video conferencing.
Build Multiple Network Groups
The NETGEAR GS105PE ProSafe Plus switch can help divide big networks into smaller more manageable groups and have resources dedicated for one or several groups rather than making the same resources open to all. This feature improves overall network performance, adds security to network traffic, and makes more efficient use of network resources.
Troubleshoot Cable Problems
This NETGEAR GS105PE ProSafe Plus switch comes with a cable diagnostic feature that enables users to easily find out the health status of their network cables. If there are any problems, this feature helps quickly locate the point where the cabling fails; allowing connectivity issues to be fixed much faster, potentially saving technicians hours of troubleshooting.
IGMP Snooping for Optimised Multimedia Traffic Delivery
By listening in on the IGMP conversation between hosts and routers, the NETGEAR GS105PE ProSafe Plus switch can maintain a map as to which links need which IP multicast streams. The NETGEAR GS105PE ProSafe Plus switch therefore will be able to forward multicast traffic only to the links that have asked for them and cut multicast traffic from links that do not contain a multicast listener. Essentially, IGMP snooping helps optimise multicast performance at Layer 2 and is especially useful for bandwidth-intensive IP multicast applications such as IPTV.
Standard Warranty: Lifetime Hardware
Key Features
5 (Five) 10/100/1000 Gigabit ports deliver dedicated, non-blocking bandwidth per port
2 (Two) 802.11af Power over Ethernet pass-through ports, maximum budget 20W
1 (One) PD port, this switch is powered by another PoE enabled device (No PSU supplied)
Delivers network monitoring, traffic prioritisation QoS and VLAN support for traffic segmentation
Simple, yet useful network set-up on top of plug-and-play connectivity
Auto denial-of-service (DoS) prevention
Troubleshoot connection issues via cable test
Loop prevention and broadcast storm controls
IGMP snooping v1, v2 and v3 support for multicast optimisation
Rate limiting for better bandwidth allocation
Port mirroring for network monitoring
Jumbo frame support
  • Prioritize voice/video
    With the ability to set up and configure QoS, this Gigabit Plus switch can detect different types of network traffic and assign the desired priority to latency-sensitive traffic, such as voice and video. This helps improve the delivery quality of related applications such as VoIP, multimedia broadcasting, and video conferencing.
  • Build multiple network groups
    This Gigabit Plus switch can help divide big networks into smaller more manageable groups and have resources dedicated for one or several groups rather than making the same resources open to all. This feature improves overall network performance, adds security to network traffic, and makes more efficient use of network resources.
  • Troubleshoot cable problems
    Gigabit Plus switch comes with a cable diagnostic feature that enables users to easily find out the health status of their network cables. If there are any problems, this feature helps quickly locate the point where the cabling fails; allowing connectivity issues to be fixed much faster, potentially saving technicians hours of troubleshooting.
  • IGMP snooping for optimized multimedia traffic delivery
    By listening in on the IGMP conversation between hosts and routers, the Gigabit Plus switch can maintain a map as to which links need which IP multicast streams. The Gigabit Plus switch therefore will be able to forward multicast traffic only to the links that have asked for them and cut multicast traffic from links that do not contain a multicast listener. Essentially, IGMP snooping helps optimize multicast performance at Layer 2 and is especially useful for bandwidth-intensive IP multicast applications such as IPTV.
NETGEAR Plus GS105PE - switch - 5 ports - Managed
Switch - 5 ports - Managed
Subtype
Gigabit Ethernet
Ports
2 x 10/100/1000 (PoE+) + 3 x 10/100/1000
Power Over Ethernet (PoE)
PoE+
PoE Budget
19 W
Virtual interfaces (VLANs): 64 , Layer 2 multicast groups: 128
MAC Address Table Size
8K entries
Jumbo Frame Support
Flow control, auto-negotiation, IGMP snooping, DoS attack prevention, port mirroring, Weighted Round Robin (WRR) queuing, Broadcast Storm Control, Quality of Service (QoS), reset button, fanless, Link Aggregation Control Protocol (LACP), DHCP client, Energy Efficient Ethernet, loop prevention
IEEE 802.1Q, IEEE 802.3af, IEEE 802.3at, IEEE 802.3az
15.8 cm x 10.5 cm x 2.7 cm
450 g
NETGEAR lifetime warranty
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
19 W
8K entries
Jumbo Frame Support
Status Indicators
Power, PoE, link/activity
2 x 1000Base-T RJ-45 PoE+ , 3 x 1000Base-T RJ-45
PoE powered
15.8 cm
10.5 cm
2.7 cm
450 g
50 °C
B8SG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
Ports: 5
Managed: Yes
POE: PoE+
Brand: NETGEAR
