Extend your range to every corner of your home with maximum network power. Establish one super high-speed connection with the dual Wi-Fi bands for your HD streaming and gaming needs. NETGEAR AC1200 Wi-Fi Range Extender boosts your existing network range & speed with the AC dual band Wi-Fi enables fast Wi-Fi performance and delivers up to 1200 Mbps. It works with any standard Wi-Fi router and is ideal for very large homes and frustration free HD video streaming and gaming.
More Wi-Fi standards
Create faster access for 802.11 b/g/n & AC Wi-Fi devices. -
Two Wi-Fi Models
Extend existing Wi-Fi connection or create a new AC Wi-Fi access point. -
Gigabit Ethernet port
Connect a wired device like Blu-ray player, game console, smart TV or streaming player to your Wi-Fi network. -
Simultaneous dual band Wi-Fi
Extend 2.4 & 5 GHz Wi-Fi up to 1200 Mbps & reduce interference. -
External antennas
For better Wi-Fi coverage & more speed. -
FastLane technology
Use both Wi-Fi bands to establish one super high-speed connection; ideal for HD streaming & gaming. -
Not in a deadzone anymore
Is there a void space between your Wi-Fi router and your devices? Add a Wi-Fi range extender and strengthen your connection for ultimate experience in connectivity. -
Mobile up to 100 % faster
Improve your mobile Wi-Fi speeds by up to 100 % with AC1200 Wi-Fi range extender! External antennas help extend Wi-Fi coverage throughout large homes and even backyards. Experience what it means to be mobile!
- NETGEAR EX6150 - Wi-Fi range extender - Wi-Fi 5
- Form Factor
- External
- Localisation
- United Kingdom
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz, 5 GHz
- 7.4 cm x 3.8 cm x 12.2 cm
- 293 g
- 2-year warranty
- 7.4 cm
- 3.8 cm
- 12.2 cm
- 293 g
- Localisation
- United Kingdom
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 1200 Mbps
- Frequency Band
- 2.4 GHz, 5 GHz
- Auto-sensing per device, Access Point operational mode, Wi-Fi Protected Setup (WPS), Push āNā Connect button, FastLane Technology
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 1000Base-T - RJ-45
- Power Device
- Internal power supply
- Limited warranty - 2 years
