NetGear EX2700-100UKS N300 WiFi Range Extender
Quicklinx: B82XWS00 Mfr#: EX2700-100UKS
  • IEEE 802.11n
Say goodbye to Wi-Fi dead zones. Convenient, discreet and easy to install, extended Wi-Fi coverage is just an outlet away with this essentials edition extender. Boost your Wi-Fi for mobile devices and connect a wired device such as Smart TVs or game consoles.
  • Extend your range tour
    Learn more about Wi-Fi Range Extenders and how you can boost your existing Wi-Fi network.
  • Essentials edition
    When all you need are the basics, Essentials Edition products are the perfect home network solution.
  • Boost N300 Wi-Fi
    Improve range and speed of your existing N300 Wi-Fi network.
  • External antennas
    For better Wi-Fi coverage and higher speed.
  • Fast Ethernet port
    Connect a wired device like a Blu-ray player, game console, TV or streaming player to your Wi-Fi network.
NETGEAR EX2700 - Essentials Edition - Wi-Fi range extender - Wi-Fi
External
United Kingdom
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
6.7 cm x 5.5 cm x 3.4 cm
98 g
6.7 cm
5.5 cm
3.4 cm
98 g
United Kingdom
External
Wireless
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Firmware upgradable, Wi-Fi Protected Setup (WPS), Push ā€˜Nā€™ Connect button
Encryption Algorithm
WPA-PSK, WPA2-PSK, WEP
IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 100Base-TX - RJ-45
Internal power supply
