NetGear 8 Port Unmanaged POE Switch
Quicklinx: BR2CWS00 Mfr#: GS308P-100UKS
Type: Gigabit Ethernet
Ports: 8
Managed: No
POE: PoE
£61.66 ex VAT
£73.99 inc VAT
The NETGEAR SOHO Ethernet switches provide easy and affordable network connectivity to small offices and home/offices. They are easy to use, reliable, and rugged with metal enclosures. With these Plug-n-play switches, you can quickly and easily expand your network connections to multiple devices, with no configuration required. These switches also support various energy saving technologies, helping you save power and money.
NETGEAR SOHO Gigabit Ethernet Switch GS308P - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
4 x 10/100/1000 (PoE) + 4 x 10/100/1000
Power Over Ethernet (PoE)
PoE
PoE Budget
53 W
Performance
Bandwidth: 16 Gbps
MAC Address Table Size
4K entries
Jumbo Frame Support
9720 bytes
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), Quality of Service (QoS), Green Ethernet, fanless, Energy Efficient Ethernet, security lock slot (cable lock sold separately), 1.5MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3az
15.8 cm x 10.1 cm x 2.9 cm
460 g
United Kingdom
3-year warranty
Enclosure Type
Desktop, wall-mountable
Subtype
Gigabit Ethernet
Ports
PoE
PoE Budget
53 W
Performance
Bandwidth: 16 Gbps
4K entries
Jumbo Frame Support
9720 bytes
Status Indicators
Power, PoE, link/activity
4 x 1000Base-T RJ-45 PoE - 15.4 W , 4 x 1000Base-T RJ-45
External power adapter
60 Watt
MTBF
2,244,211 hours
CB, CCC, FCC Part 15 A
United Kingdom
15.8 cm
10.1 cm
2.9 cm
460 g
Limited warranty - 3 years
10 - 90% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 95%
Ports: 8
Managed: No
POE: PoE
Brand: NETGEAR
