Network Control So Easy. It's Like Magic
Netgear genie makes getting the most out of your home network fun and easy. More than four million downloads of the genie App lets users easily monitor, connect and control their home network from a PC, Mac, tablet or smartphone. With Netgear genie you can share and stream music or videos, diagnose and repair network issues, set up parental controls and more.
N300 WiFi Router 802.11n
The high-performance, wide-ranging, fast-downloading N300 Wireless Router.
It's the ideal router for the well-connected and well-entertained home. Designed to deliver the performance needed for applications such as HD streaming, online gaming and fast downloading, the N300 Wireless Router offers speeds of up to 300 Mbps, external 5dBi antennas for improved WiFi coverage and Live Parental Controls for safer web surfing on connected devices.
Speed
Instant emails. Fast web browsing. Smooth video. Lag-free gaming. Speed makes a big difference in your online work and life. And with download speeds up to 300 Mbps, the N300 delivers.
N300 WiFi, Faster downloads and Internet gaming
WiFi Range
Upstairs, downstairs, in the kitchen, in the office, even in the garage. At NETGEAR, we know you want and need great WiFi throughout your home. The N300 Wireless Router with external antennas delivers--with reliable range for medium-sized homes.
Sharing
Relive memories and share them with others. Enjoy photos, videos and music. If it's secure and shared storage access you want NETGEAR has easy ways to do it.
Ease of Use
NETGEAR makes it easy to set up your network and to do more with your digital devices. Use Push `N' Connect to add devices to your WiFi network with a push of a button.
Reliability
There's nothing more frustrating than lost connections. With Netgear's enhanced features and some of the best-in-class technology, you'll reduce interference and enjoy more reliable Wi-Fi connectivity.
Security
Guest networks create a completely separate WiFi network for your guests' devices, ensuring they do not have access to your home network. Secure WiFi connections offer WPA/WPA2 security and free parental controls keeps your family safe from unwanted content.
Parental controls, web filtering for all your connected devices
Guest network access, separate and secure access for guests
Secure WiFi connections with WPA/WPA2
Memory: 4 MB flash and 32 MB RAM
Five (1 WAN, 4 LAN) Fast Ethernet ports
WiFi Protected Access (WPA/WPA2--PSK and WEP)
Double firewall protection (SPI and NAT firewall)
Denial-of-service (DoS) attack prevention
xposed Host (DMZ) for secure gaming
- NETGEAR JWNR2010 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Routing Protocol
- RIP-1, RIP-2, static IP routing
- Firewall protection, DMZ port, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), Push ‘N’ Connect button
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 17.3 cm x 14 cm x 3.5 cm
- 200 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Routing Protocol
- Encryption Algorithm
- WPA-PSK, WPA2-PSK, WEP
- RAM
- 32 MB
- Flash Memory
- 4 MB
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Gain Level
- 5 dBi
- Power Device
- External power adapter
- OS Required
- 17.3 cm
- 14 cm
- 3.5 cm
- 200 g
- Limited warranty - 2 years
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
