NetGear Gigabit Ethernet 10/100/1000 Mbps 8 port Switch 300 Series
Quicklinx: 8F4GWS00 Mfr#: GS308-100UKS
The NETGEAR 300 Series Unmanaged Switches provide easy and affordable network connectivity to home and small offices. They are easy to use and reliable. With these Plug-N-Play switches, you can expand your network connections to multiple devices instantly. They also support the efficient use of energy, helping you save power and money.
  • Gigabit Ethernet connectivity
  • Metal enclosure
  • Energy-efficient technology for power savings
  • Auto-MDI/MDIX eliminates the need for crossover cables
  • Non-blocking switching architecture for maximum throughput at wire speed
  • Auto-negotiation for automatic connection at the highest common speed between switch and an end device
  • Fan-less design for quiet operation
NETGEAR GS308 - switch - 8 ports - unmanaged
Switch - 8 ports - unmanaged
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
MAC Address Table Size
4K entries
Auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab
15.8 cm x 10.2 cm x 2.6 cm
400 g
United Kingdom
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000
Performance
Bandwidth: 16 Gbps
4K entries
Status Indicators
Power, link/activity
8 x 1000Base-T RJ-45
External power adapter
3.8 Watt
United Kingdom
15.8 cm
10.2 cm
2.6 cm
400 g
10 - 90% (non-condensing)
