The NETGEAR 200 series unmanaged switch provides easy and affordable network connectivity to home and small offices. It is easy to use and reliable. With these Plug-and-Play switch, you can expand your network connections to multiple devices instantly. The 200 series also supports the efficient use of energy, helping you save power and money.
- NETGEAR FS205 - switch - 5 ports - unmanaged
- Switch - 5 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- Performance
- Bandwidth: 1 Gbps
- 11 cm x 7.1 cm x 2.6 cm
- 100 g
- Localisation
- United Kingdom
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- Performance
- Bandwidth: 1 Gbps
- Status Indicators
- Power, link/activity
- 5 x 100Base-TX RJ-45
- Power Device
- External power adapter
- 2.3 Watt
- Localisation
- United Kingdom
- 11 cm
- 7.1 cm
- 2.6 cm
- 100 g
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
